Fuse blows-anti-lock light comes on & more
Happened the other day, the anti-lock light came on, I also noticed the A/C controller panel lights went off. Checked fuse and turned out the fuse that's for the anti-lock and A/C control panel had blown. Went and replaced fuse, car worked ok for a day or so then when I went to start the car, the fuse blew out again. It blew out before I turned the ignition to start the engine. Only thing I can think of that may be adding to the problem is the day the fuse went out I had to use the parking brake, something I don't generally use cause one of these days I'm going to have to adjust the cable. When I took the parking brake off, the parking brake light stayed on. I had to put the parking brake on again and then do a hard release so lever could engage the switch that turns the parking brake light off. Could that have anything to do with it? What's causing this fuse to blow?
Looking forward to your help.
George
George
What year is the car? There was a major revision of the fuse panel in 1990 so it's important to know which year your car is.
Which fuse is blowing? What is the label on the fuse panel?
Thank you,
George
