Let's build a single plane efi intake
#41
Use a thermostat housing from a factory GM TPI manifold.
I believe these are the lowest profile availiable for the SBC and will help out a ton with TB clearance on the bottom side.... They are faily cheap too at 26.00 USD.
http://tpiparts.net/inc/sdetail/11909/292
Will
Will
#42
Like this?
my name is Larry and I'm taking my talents to the C6 section
http://forums.corvetteforum.com/c4-t...post1586944254
#43
Like this?
Any problems with your external coil cap adapter hitting or rubbing on the hood? I ended up cutting a hole in my hood for clearance. You should mount your coil more away from your header.
http://forums.corvetteforum.com/c4-t...ting-hood.html
#44
Will
Will
#45
Like this?
#46
Received 1,741 Likes
2023 C5 of the Year Finalist - Modified
St. Jude Donor '09-'10-'11
Here is my single plane setup, but it does not clear the stock hood.
I have no data on it yet. Life events have kept me from taking it to the tack or dyno. As for things I had to change, I went to a small cap disttibutor and remote coil for the air filter to clear, I mounted the MAP sensor to the firewall, and had to drill and tap for some vacuum fittings. Since I also converted to an LS style throttle body I needed some pigtail adapters, but other than that the single plane was pretty much a drop in.
#47
That should work well with the cowl. Filter looks a little small, I'd try an oval style maybe get a little more surface area. Still I don't know the dimension compared to the oval one or if yours is a dual cone style and not even sure is I like dual cone style.
http://www.kartek.com/Product/573/Ov...hrome-Top.aspx
#48
Sorry Kubs, I think I referenced someone else earlier in this thread when I was thinking of your setup.
Your setup still has me wanting to do that to take advantage on the L88 scoop.
#49
If you have any questions I'd be glad to help. Nice to know I inspire people.
#51
Pro Mechanic
Way to tell if the filter is a restriction is to look at your MAP values at WOT through the RPM range and look for any value lower than the value shown for atmosphere (KOEO).
#53
It would do neither. It's a MAP system (and not a carburetor), so it will provide the right amount of fuel for what ever the plenum pressure is...a restrictive filter would behave very much the same as a restrictive TB...or even as the TB not at WOT. Doesn't go rich or lean when you start closing the throttle does it?
#54
Hey Kubs with your manifold water temp sensor, did you use an adaptor ?
I was looking at where to put it, the sensor is about 5/8" thread but the threaded hole in the manifold is bigger (a 3/4" will fit in that hole)
If i use an adaptor and it sticks up too far it will most likely hit the bottom of the TB / IAC.
#55
My manifold had 4 bungs I could have used. Two in front and two in back (next to the distributor). Is there one out of the way you could use?
#56
thats an idea,
but if i used a rear bung would it matter if it takes its water temp from a place where the water comes to a stop so far from the thermostat ?
#57
Im not sure if it would matter or not. You could also put it in the head. Each head has a port (also 3/4" I believe) but only one is used for the gauge.
#58
I was thinking it would come up to temp quicker at the rear as it would be reading water in the engine block, opposed to the front sensor location which is reading water on the radiator side of the thermostat ?
It would just mean it would go into closed loop mode quicker if the sensor was at the rear.
#59
Pro Mechanic
In reality, it's not going to matter one bit. Water is circulating fast enough that the temp at the rear of the motor will be a couple degrees different than the front, at most. Either way, it's ALL on the "same side of the thermostat" -which is the "engine side". What is on the other side is the upper radiator hose.
#60
[QUOTE=Tom400CFI;1586972104]
yeah i didnt explain that well, what I was referring to is cold start up, the water wont be moving anywhere in the engine coz the thermostat is closed, it would circulate slowly in the block as the hot water rises i guess, which means that point at the rear of the heads/manifold would get hotter sooner, and if the sensor is at the rear, go into closed loop sooner, well that is my theory anyway
but your right, I doubt there would be much difference overall.
I just raised the question in case someone piped up and said "dont do that because of (insert reason here)"
/QUOTE]
/QUOTE]
