Whos Running CorvetteCentral exhaust 324148- h pipe w/magnaflow mufflers
Highly considering purchasing this kit.
Was wondering if anyone else decided to run it?
If you did are you happy with it and do you have a drone issue in the car?
How is it holding up?
I had mine installed late last year on my '84 with a 4+3, and I am not too pleased with the way they hang near the rear axle. The pipes sit way too low. There's no mounting point to pull them up tighter.
I contacted Corvette Central for help, but they had no suggestions. They don't sell mounts for the location near the rear axle.
I haven't messed with it yet, because I am getting a Tremec installed next week and the exhaust will have to be moved for the new transmission.
I am hoping I can take it to a exhaust shop to see if they can tighten it up and mount it better.
Wow that really is low. I wonder if mine would sit better since my car is a 95.
do you have a sound clip?
Do you have any pics of them attached in the front? How was the h pipe welds?
You are probably better off going to an exhaust shop but if you want an alternative, I just used the cheapest muffler straps I could find and wrapped the strap around the sway bar. No drilling, welding or adjusting -- it's just plain bubba.
I have long spring bolts to lower the rear of my '87 so I wanted to get the exhaust up as high as possible. Here's the result:
And here's the hanger strap:
I am considering one of those systems myself. I would love to see one installed also. 2 3/4" and mandrel bent according to CC
