what is this? off tach output on distributor.
That is a tach filter. You remove that when you install and ignition box such as and MSD 6AL2 because they have their own tach filter inside. If you bypass that, (the connectors will plug into each other), your digital dash display will flicker and go crazy and be illegible. Also, the bracket is a ground for the filter and it has to be grounded.
Great. Ill prob just solder a ground wire for it cause I doubt ill get it grounded again.
Where should it bolt? Only potential thing I see is back of block over bell housing....
It DOES need to be grounded. On some years it's attached by a bolt on the intake manifold. On most years it goes under the top bolt on the driver's side of the bell housing (as shown in the picture).
