88 C4 - CLUSTER BULB replacement question and whats behind the hazard switch
ok I have the bezel off I see the instrument cluster and the silver circles that hide the bulbs, I have one bulb dead - is there a way to pop those out without removing the whole cluster from the dash on my 88 c4
also behind the hazard switch on the steering colume there are 3 screw holds in the shape of a triangle on the front of the dash does someone have a picture they can show me of what goes there, I cannot find or figure out what originally went there .
thanks all
thanks all
The silver reflectors pop out. Stick something sharp in one of the holes and pull it out.
There are various ways to get the bulbs out. Some people use a piece of rubber hose, but that can be problematical if the hose diameter is too large. I have wrapped masking tape around the bulb and pulled it out. I have heard of using long-nosed pliers, but I would be afraid of breaking the glass. There are also specialty bulb pulling tools if you don't mind spending some money for something you will rarely use.
These are halogen bulbs, so be careful about getting skin oil on the glass. It causes localized hot spots and can make the bulb shatter. You can clean them with alcohol.
There is a small plastic piece that goes there to protect the dash from getting dinged up when your keys bounce around while driving. It doesn't seem to work very well because the area around that piece is marked up on my car.
Make sure you don't twist the bulbs as you are trying to remove them! If you do, the bulb socket tends to unlock and fall out of the backside of the circuit board, which means pulling the cluster.......ask me how I know........
