Go Back   Corvette Forum > C4 Corvettes, 1984 - 1996 > C4 Tech/Performance
Register Forgot Password?
Register Albums Search Today's Posts Mark Forums Read FAQ
Search
C4 Tech/Performance
L98 Corvette and LT1 Corvette Technical Info, Internal Engine, External Engine Sponsored by
J&D Corvette
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 07-18-2002, 08:03 PM   #1
YellowFvr
CF Senior Member
Default How much does a c4 weigh?
Lets say 1/2 tank of gas and 180 lb. driver?
YellowFvr is offline   Reply With Quote
Old 07-18-2002, 08:05 PM   #2
scorp508
CF Senior Member
scorp508's Avatar
Depends on the year and model.
My '87 coupe is 3365 with me and 1/3 tank of gas in it.
scorp508 is offline   Reply With Quote
Old 07-18-2002, 08:09 PM   #3
YellowFvr
CF Senior Member
Default Re: (scorp508)
92-96 coupe?
[Modified by YellowFvr, 12:11 AM 7/19/2002]
Old 07-18-2002, 08:33 PM   #4
95AquaC4
CF Senior Member
95AquaC4's Avatar
Default Re: (YellowFvr)
Quote:
92-96 coupe?
3256 lbs. me and half a tank of gas. I weigh 165.
[Modified by 95AquaC4, 7:34 PM 7/18/2002]
95AquaC4 is offline   Reply With Quote
Old 07-18-2002, 09:03 PM   #5
65Z01
CF Senior Member
Cruise-In II Veteran
65Z01's Avatar
Send a message via AIM to 65Z01
Default Re: How much does a c4 weigh? (YellowFvr)
Sat. with 1/3 tank of fuel I was launching at 3,350lbs; I weigh 165.
So, I would estimate your setup at 3,385lbs (+15lbs driver & +20lbs fuel).
65Z01 is online now   Reply With Quote
Old 07-18-2002, 09:08 PM   #6
YellowFvr
CF Senior Member
MAN! my c4 weighs pretty much the same as a z06?! i thought c5's were supposed to be lighter?
Old 07-18-2002, 09:10 PM   #7
James94LT1
CF Senior Member
James94LT1's Avatar
I thought C5's were actaully heavier?!?!?
James94LT1 is offline   Reply With Quote
Old 07-18-2002, 09:22 PM   #8
J Z06
CF Senior Member
J Z06's Avatar
Send a message via AIM to J Z06
Default Re: How much does a c4 weigh? (James94LT1)
1990 Coupe, I weigh 160 with a half tank and me in it, 3350 Full Tank 3425 :U and I still did 116 in the 1/4!
J Z06 is offline   Reply With Quote
Old 07-18-2002, 09:38 PM   #9
BobMachus
CF Senior Member
BobMachus's Avatar
Default Re: How much does a c4 weigh? (JD 90 383)
My '88 vert weighs 3400 with just under 1/4 tank and 160 lbs me, with spare tire.
BobMachus is offline   Reply With Quote
Old 07-18-2002, 09:54 PM   #10
CFI-EFI
CF Senior Member
CFI-EFI's Avatar
My stock, '84 weighs 3245 with a FULL tank of gasoline, no one inside.
CFI-EFI is offline   Reply With Quote
Old 07-18-2002, 10:48 PM   #11
Black 'n Blue
CF Senior Member
Black 'n Blue's Avatar
:yesnod: but only if you include the golf clubs.
Black 'n Blue is offline   Reply With Quote
Old 07-18-2002, 10:50 PM   #12
0ski_dwn_it
CF Senior Member
ski_dwn_it's Avatar
Default Re: How much does a c4 weigh? (CFI-EFI)
3350 with me @200 lbs and a 1/4 tank+spare
ski_dwn_it is offline   Reply With Quote
Old 07-19-2002, 01:32 AM   #13
The Green Rocket
CF Senior Member
The Green Rocket's Avatar
My fully optioned Vert, with the auxillary hardtop installed and ~ 1/3 tank of fuel weighed in at 3,410 lbs at LACR, that is without me inside.
Thomas
The Green Rocket is offline   Reply With Quote
Old 07-19-2002, 01:43 AM   #14
rcolling
CF Senior Member
rcolling's Avatar
Send a message via Skype™ to rcolling
Default Re: How much does a c4 weigh? (The Green Rocket)
I weighed my LT4 with 1/2 tank of gas. It has the spare tire delete and without me in it it weighed 3285.
I did mine just before Thomas' at LACR.
rcolling is offline   Reply With Quote
Old 07-19-2002, 11:07 AM   #15
War Machine
CF Senior Member
War Machine's Avatar
Location: Airport Cruise-in 1 Veteran Airport Cruise-in 2 Veteran
For the 93 I see Coupe (3,317) Vert (3,358) ZR1 (3,503). No stats for this topic on the 94 where I got this info.
CURB WEIGHT
The curb weight of a vehicle is the weight of an unmanned vehicle with fuel, oil coolant and all standard equipment installed.
http://corvetteactioncenter.com/specs/1993.html
This will all depend on your options. The best method is go to the track and jump on the scale if they have one. My 87 curb weight is supposed to be 3325 but I have bare minimum options ( I don't even have power locks) and have taken out the spare tire/jack and the vanity mirrors bringing the curb weight down to 3150 w/o driver.
[Modified by War Machine, 9:09 AM 7/19/2002]
War Machine is offline   Reply With Quote
Old 07-19-2002, 11:52 AM   #16
daddydahlin
CF Senior Member
daddydahlin's Avatar
Send a message via AIM to daddydahlin
Default Re: How much does a c4 weigh? (War Machine)
Curb weight of a 86 coupe is 3082
daddydahlin is offline   Reply With Quote
Old 07-19-2002, 01:56 PM   #17
SPD DMN
CF Senior Member
Cruise-In I Veteran
SPD DMN's Avatar
Default Re: How much does a c4 weigh? (daddydahlin)
Well hell, mine is a pig! It weighs 3420 with me in the drivers seat (240), full bottle o' Nitrous, roll bar and side bars installed and 3/4 tank of gas.
Oh, but my spare tire and carrier are not installed ;).
SPD DMN is offline   Reply With Quote
Old 07-19-2002, 02:10 PM   #18
Shriker
CF Senior Member
Shriker's Avatar
C4's generally are between 3200 and 3500+ depending on what year and car. The early C4's are the lightest (as evidenced by the postings in this thread) , some down in the low 3200 lb range full of all fluids and without a driver (totally stock). As the years went on more weight was added in more frame support , more equipment , bigger wheels tires and brakes, etc.
The latest C4's tend to weigh 3340-3380 depending on the options etc. My personal 96 LT-4 totally stock weighed 3340 lb full of all fluids and without me in it. My car is fully optioned .
ZR-1's usually range from 3450-3520 or so full of all fluids, no driver.
C5's are indeed lighter than our C4's with most loaded coupes being around 3225, most hardtops being 3175 and most Z06's 3115-3125 - again , full of all fluids , no driver.
All this is based on the numerous books I have read, magazine tests, and most importantly local track scales. Hope this helps....... :seeya
Shriker is offline   Reply With Quote
Old 07-19-2002, 02:24 PM   #19
Zora
CF Senior Member
Cruise-In I Veteran
Zora's Avatar
If I remember my 95 weighs 3160lbs. that's without my 240lbs AZZ. :D
Zora is offline   Reply With Quote
Old 07-26-2002, 12:01 AM   #20
C4ForGeeGee
CF Senior Member
C4ForGeeGee's Avatar
Default Re: How much does a c4 weigh? (Zora)
My 1994 LT1 Coupe weight was 3309 without my 170 lbs. in it. 1994 was a heavy year judging by the American Cars encyclopedia, I love that fat Beast :lol:
C4ForGeeGee is offline   Reply With Quote
Reload this Page How much does a c4 weigh?
Tags
1990, 1996, 2000, 84, 87, 94, 96, c4, c5, corvette, schecter, versus, vette, weigh, weight
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
How much does a litre of gas weigh? 1Bad69 C3 Tech/Performance 29 07-14-2013 02:40 PM
weight of a C4 Alcee1 C4 General Discussion 12 10-08-2004 09:31 PM
How quick are the 6 gear 350Z? 88BlackZ-51 C4 General Discussion 35 05-01-2004 05:02 PM
How much does the C5 weigh?? jschell C5 Tech 26 01-20-2003 07:38 PM
4L80E in a C4 Light84vette C4 Tech/Performance 32 11-21-2002 12:18 PM
How much does your C4 weigh? sinistervette C4 Tech/Performance 11 09-12-2002 04:03 AM
LT1 C4 info? Dolby109 C4 Tech/Performance 41 08-17-2002 02:53 AM
Anyone ever weighed they C4? 84Coyote C4 Tech/Performance 28 01-02-2002 02:52 PM
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
