two step on an auto?
This may seem stupid to some or most, but im curious I love the sound of 2step and was wondering it is was possible on an auto car? I dont even need it for launching, just love the sound of the rev limiter bounce but obv dont want it up at 6k or whatever it redlines at.. is there any other or better way to do it?
It's possible, but I would think it's just a waste of money just using it for the sound... It motor vibrates like hell when I use my 2 step, so I'd imagine if you aren't using it for racing all you'd do it either wear out the motor mounts prematurely, or possibly flood the engine using it and possibly wash down the cylinder walls if you use it excessively.
Funny you should mention that. I just did it the other day at a traffic light and as soon as I let off there was a huge backfire that came out of the tail pipe, sounded like a gun shot. Everyone walking by ducked, and everyone in their cars was looking around like WTF!?
I use a 2 step with my automatic for bracket racing. I don't floor the gas pedal. I push it down until the motor starts to miss and get ready to launch. Flooring the pedal just loads up the motor and fills the crankase with fuel because the injectors keep injecting but the spark does not happen to alternating cylinders. The ***** on the left control the launch rpm. One is for 1000s and the other for 100s. With a tighter converter, I used to launch at 2000rpm. Now with a looser converter and double disk brakes on each rear wheel, I can set the launch rpm at 3400. The 2 step allows the driver to concentrate on the lights instead of looking at a tach.
"You rev while stationary, and the "2 step" stops your revs at a certain predetermined rpm. You keep the gas down so that it "bounces" off this secondary rev limiter, which allows you to launch more consistently. The launch rpm and how you choose to utilize it is up to you..."
Apparently, the 2-Step device allows for a second rev limiter for you to set for your launch RPM.
I didnt plan on using it for racing mostly because I prob wont race it much and I wasnt sure how it works with an auto.. im assuming you have to use a button or something to act as a clutch pedal in a manual.. I just like the sound of the limiter and I would use it mostly just for a bit of fun, I have the 6AL but I dont believe that is the one that has the limiter on it, I just couldnt imagine using that to do it if it does because it is almost under my dash on the passenger side haha
You have a rev limiter on the 6AL, so if you want you can turn down the rev limiter RPM to whatever you like and bounce off of that. Or you can set it to your actual desired redline and bounce off at red line so you don't have to reset the dial when you're done having fun.
