Built vette timing issue
Max G’s
My suggestion would be to find someone in your area that can dyno tune the new engine combo. The injectors probably need to be tuned as well.
Okay, a 30 lb (number that begins with 280-15x-xxx would be preferred) at an installed 43 is about right. Put a scanner on it and if it's running rich it will show a blm of 108 (128 is perfect). Contact Ed Wright and tell him your flowrate is not correct. You need to tell him you have a problem, and the steps you took to determine the cause.
