94 keeps shutting off out of no-wherre
94 could this be the opti......this would be the third in the last year!!!
could I be this luckly ....
Have replaced ICM and wires connected-( I have a question about ICM is the 92 and 94 vette have the same ICM or different part number)
I have also replace the coil ...still shuts down.
Could this be the opti ......does this sound familar to anyone?
PS
if this is opti.... what brand and where do get a desent replacement opti ???
PS
If you have went through 3 Optis in the last year, something is wrong.
Either crappy parts, bad install, or the problem is somewhere else.
When it is running, is it running good? If so, it probably isn't the Opti itself.
Still on my factory original Opti in my '96, with over 120k miles
PS
PS
See if there is a code for the opti. It would be 16.
How long does it shut down for?
You may need to measure the voltage for the ICM from the ECM for more data.
