Fuel leak
Fuel leak
Hey guys, I am getting ready to fire up my engine that I just put AFR 195 heads on.
I did a fuel pressure test on it to find some leaks, I found a lot, mostly all O - Rings.
Now when I test it the pressure drops down and settles at around 50 ish, but I don't see any fuel leaking anywhere and I can't hear anything purging out. The pressure goes to 75 while the pump is priming then kicks down to like 60 and drops to 50 in about 15 seconds.
Any ideas? I have to still adjust my FPR but after I clear up all the leaks.
Thanks!
Thanks!
