LS-1 in a C4?
2nd Gear
LS-1 in a C4?
Alright first off, this is my first post, and I obviously don't know as much about vettes as the rest of you,
So, I was wondering, is it possible to by an LS-1 as a Crate engine?
If so how well does it fit in a C4?
Thanks,
~Murph
Thanks,
~Murph
Re: LS-1 in a C4? (tvgm84)
Yes, you can buy an LS1 crate engine, and it will fit into a C4. There is someone on the forum that has done it to an 80's model vette...'84 I think? But I am drawing a blank on his forum name...
Re: LS-1 in a C4? (LT5FIRE)
I don't have the time/place/or money for this right now,....but have been knocking the idea around for a while.
I love the C4 body style,.....and the LS-1 is an awesome motor.
Hmmm,....maybe if I win the lotto you'll see a MTI prepped 422ci LS-1 Polo Green C-4..... :D
2nd Gear
thanks, but...
does anyone know how much the crate engine would cost? also would it have the same hp as the C5 or would it be on the level of a Z-28?
Cruising
Re: LS-1 in a C4? (vetteman9368)
I'm actually in the process at the moment change the mountsn a little bit and some small firewall mods & small change to the fuel rails & tappet covers I'm also going to a motec which is pretty trick set up linked back through the original ecm costing me plenty but mines been modied to righthand drive so some of the issues I had with wiper motors @ such shouldn't be an issue over there but I wouldn't reccomend it to an average backyard mechanic .If you want the email adress for the bloke thats doing mine @ manta racing in ausyralia let me know
My AIM is LS1C4 and new e-mail is LS1C4@charter.net. Let me know if I can be of any assistance :cheers:
Regards
Trace
I'd only pursue this if you want the lighter weight aluminum motor and its cheaper than going with an aluminum L98 small block.
Otherwise, build a 550 hp 420 ci small block.
