Stock air filter box replacement 1986
Any good ideals for replacing the stock air filter box on my 1986. I have done a bunch of mods an wondering if is a restriction now.From what i have found it flows 631 cfm an 657 with cut lid. Mods include.
355 cu 9.5 comp
180 brodix heads
comp cam- 260 272
.499 .493
1 5/8 Headers 2 1/4 w cross over [no cats]
24 lb injectors
Tpis big mouth intake
AM&S runners.
48 mm throttle body.
Tune by pcms for less.
355 cu 9.5 comp
180 brodix heads
comp cam- 260 272
.499 .493
24 lb injectors
AM&S runners.
Breathless Performance still shows their C4 "Vortex Ram Induction" intake as being available.
This system installs in place of the OEM intake and you cut a hole in the flat panel in front of the radiator/condenser where the OEM box sat. Air goes under the front fascia and up into a conical shaped air filter.
I have the C5 version on my '02, and it works well for getting lots of intake air into the supercharger. The only issue I see is that it "could" take in water if you went through a deep puddle of water.
