not a good day at the track!!
Received 19,432 Likes
'20-'21-'22-'23-'24
Good luck with the repairs.
Sucks, hope you get it fixed fast! I see your time is in the 11sec how old are the u-joints? Drag radial or street tire? Auto or manual?
edit: Did it break on launch or down the track?
Wow, guess its a good thing you trailered it there? Give me a shout if you want an extra set of hands for the repair.
Pro Mechanic
^That is usually only a problem in C5^ cars. My C6 was terrible that way. My C4 never does it.
[QUOTE=BOOT77;1586121644] I see your time is in the 11sec how old are the u-joints?
About 12 years, 20,000 miles and about 1,000 1.6x 60ft passes
When it broke it was drag radials. Used to be bias plys
Auto or manual?
Automatic, 3,000 stall, 3.73 gears
Did it break on launch or down the track?[/QUOTE]
Launch or just a little latter.
Auto or manual?
FWIW I would always check the joints for slack, but they were tight. I kept them greased with the mobil syn. grease. With as many runs as I had, I should have replaced them anyways, and probably with solid joints as well. At least that's the plan when it goes back together.
I was gonna say if it happened after launch. It almost looks like housing side it sheared the strap bolts on one end and then the other side of that u-joint broke off. Flung around some before the wheel side u-joint broke.
I don't think it did that. The shaft was on the track about 50ft from the start. But again, when these things happen its quick and then with a helmet on, its harder to hear.
Last time I broke one of those it also took my batwing out as well as creating a nice hole in my right storage bin. Make sure you use a non-greasable u-joint such as Spicer.
Pro Mechanic
Lol...'cause trucks don't break? I'd like to know what kind of truck that is. Good luck!
