Spark Plug Gap Question
I'm installing NGK 7173 spark plugs. They are a heat range 8 plug. My current plugs are reading as white, so I'm going to the cooler plug. The NGKs are gapped at .030 out of the box. My older plugs were gapped at .045. So the question is the correct gap for the 7173s?
motor? year?
Most of the time it's wise to start at the stock gap (.035) and work your way up until the motor starts loosing power , then back off to the previous gap where it ran best ..You will probably end up somewhere around were you had them gaped before (.045)..It all has to do with your compression and your ignition system... #8 is a pretty cold plug, what is your compression ratio.??.. Im at 10.25 to 1 and running an NGK 7373 (FR5) with a heat range of (5) ...The way most people read plugs is to do a run, shut the motor off immediatly, then read the plug..Letting the engine run to long fouls up the reading....WW
Most of the time it's wise to start at the stock gap (.035) and work your way up until the motor starts loosing power , then back off to the previous gap where it ran best ..You will probably end up somewhere around were you had them gaped before (.045)..It all has to do with your compression and your ignition system... #8 is a pretty cold plug, what is your compression ratio.??.. Im at 10.25 to 1 and running an NGK 7373 (FR5) with a heat range of (5) ....WW
Stock or aftermarket ignition?
8 does seem cold and if you use a smaller gap. Still give it what it wants!
