Pulling of intake and runners what size TORXS
Going to go buy, what sizes do i need to purchase?
Re: Pulling of intake and runners what size TORXS (AshleyRL-87Conv)
If you are going to do any other work on the car you might as well get a whole set as you will find torx bolts all over the place. A set is only a few dollars more than one or two by themselves.
Re: Pulling of intake and runners what size TORXS (C4-Wolf)
Like C4Wolf has stated above, purchase the entire set, you will need them for other things.
Vic
Vic
Location: Airport Cruise-in 1 Veteran Airport Cruise-in 2 Veteran
1 Post
Cruise-In II Veteran
I've used the T-15? (the size used on the ditributor cover) so many times it eventually broke. Out of my whole set I think there is 1 or 2 that I haven't used yet.
Re: Pulling of intake and runners what size TORXS (Vic'89)
Buy the whole set, make SURE you spend the extra cash to buy a GOOD set. Cheap sets tend to cause more harm then good, they strip and sometimes can cause you to strip the torx heads because they don't fit in properly (trust me I found out the hard way, now the only tools in my box are Craftsman). :yesnod:
Just my .02.
Just my .02.
Re: Pulling of intake and runners what size TORXS (VetBoy89)
Well guess Im off to sears tommorow Thanks guys :cheers: :smash:
Buy the set, you also need them to change the bulbs in the high mounted brake light. :yesnod: :seeya
