What is your RWHP and what did it take to get you there?
I think it would be interesting to see what wheel horse power guys are making with their little ol C4 corvettes and what mods it took you to get there.
Post what ya Got!
Post what ya Got!
404hp and 405ftlb, 120mph at 1/4 mile
Lt4 383cid
Port and polish stock heads
Port and polish stock intake
Comp cam cc503 with 114lsa
1.6 rockers
Rhoads lifters
58mm bbk throttle body
Stock maf (with screen)
Kn cut lid filter
32lbs bosh III injectors
Melrose long tubes
3" metal cats
2,75" duals with one center muffler and no mufflers at back
Lt4 383cid
1.6 rockers
Rhoads lifters
Kn cut lid filter
Melrose long tubes
3" metal cats
Lt4 383cid
1.6 rockers
Rhoads lifters
Kn cut lid filter
Melrose long tubes
3" metal cats
Nice numbers with stock heads!
380. Previous owner did the work (see signature), I wrote a check...
I'm in the middle of an LS1 swap. Hoping its close to the same.
Pro Mechanic
2018 C4 of Year Finalist
2015 C4 of the Year Finalist
St. Jude Donor '16
430rwhp 380tq,
Headers, Corsa's, Ported intake thru heads. 63mm throttle body.
St. Jude Donor '16
My car made 528/517 on a Super Flow Dyno.
383 lt4
Afr 210 Comp port heads
lt4 port matched intake
Comp 280 XFI cam
jesel shaft mounts
bbk 58 mm TB
Ltcc conversion
ARH 1 7/8 set headers with 3' magnaflow exhaust
7.5 psi p600b
I am taking the car to TPIS for further tuning. I believe It has more in it with a better tune.
383 lt4
Comp 280 XFI cam
jesel shaft mounts
bbk 58 mm TB
Ltcc conversion
7.5 psi p600b
409 RWHP
383 12:1 LE ported TFS 195's ( now 205 ), crappy old 847 cam
LT's ,dual 3' exh
Dynoed with 750DP on Vic Jnr intake , soon to be replaced with Vic E and 1200cfm 4bbl TB
Flatlined from 6200 -7000 , will make more with larger, not so street friendly cams I have
LT's ,dual 3' exh
462rwhp.
385ci, 11.3 compression 232-236 594 lift cam. AFR 210 heads, LT4 intake, 58mm TB, 1&3/4 headers, Stock exhaust including resonator but with Magnaflow mufflers. 3000 stall converter, 3.73 gears.
Whats she weigh anyway?
Thanks for the compliments. Will (rklessdriver) did a great job picking parts, and putting it all together.
Not sure on weight. Its all stock vert with a hardtop so its pretty heavy. My best run was 11.19 at 124.6x. But we were having problems with it cutting out and shifting early. I hope to get back to the track soon, maybe feb. 7th, and better those numbers.
BTW that is on e85. Was never dynoed on pump gas. Ed figured I would loose 10-20 hp on gas. If I get to go to the track feb. 7th, I will have 6 hrs to play, so I plan on trying both fuels to see what difference it makes.
