C4 Corvette 4+3 manual transmission exploded view
Hi!
I'm new to this forum and I was wondering if someone could help me out with findning an exploded view of the C4 4+3 manual transmission. Since I'm new here, I'm having a hard time finding one!
Thanks!
Thanks!
Why I'm interested in the exploded view is because I was wondering if I have to "connect" the last three gears to have the car going, or can I just ignore "connecting" them?
I'm sorry if the question is confusing, I'm not that good at english and terms differ from different languages
The gearbox is a BW Super T10 4 speed with a 2 speed O/d attached at the rear so you have a 4 speed trans with overdrive available on 2nd , 3rd and 4th
that give the extra 3 gears
Depending on what the problem is (mechanical or electrical ) causing the O/d unit to not work which I assume is the question you are asking ?
you can possibly still drive it as a 4 speed without using the O/d
Explain what your problem is and we may be able to help you fix it
Electrical problems are common with age and it may only be a faulty relay or bad wiring that is stopping it from working
In the pic you can clearly see the O/d unit attached to the rear of the Super T10 gearbox
It woud also help to let people know the year of the car. While the 4+3 is pretty much mechanically the same, operation on the OD is different depending on the year. Here's a good link to how the OD operates by model year.
Also, if you intend to do any work on the car or transmission yourself, it would be a very good idea to get a Factory Service Manual (referred to as an "FSM") for your specific year of car. There will be a section in the book that has everything you are looking for, including exploded views and step-by-step instructions for tear-down and reassembly. FSM's can sometimes be found in the C4 Parts For Sale section or on eBay.
Check Ebay, as well. I saw someone on there selling 4+3 OD rebuild manuals for $20 a piece. You can still run the car without the OD but last person I talked to who ran it without one said it was screaming at certain speeds. I thought about rebuilding an old 4+3 I had and I REALLY wanted to but the OD section seemed so finicky. There's an old pic floating around here from the "101 projects for your Corvette" that details graph-style with a particular rear gear what speed and rpm 1-4 allowed with and without OD operation.
You don't have " 3" last gears.
Thank you for all the great responses! I recently came home from a vacation, so I haven't been able to respond.
The thing is, I'm building a AC-Cobra replica, which is all Corvette under the hood. I was wondering how you would connect and set up this transmission without the overdrive enabled, in a safe way. Would I need to fill the overdrive unit with oil? And how would one connect and wire correctly for this to work?
Your help is greatly appreciated! And I hope I'm making myself understandable..
sse94 (09-23-2018)
sse94 (09-23-2018)
