Help with LT1/LT4 Compatibility.
Old 12-20-2013, 10:39 PM
l98tpi
Max G’s
Support Corvetteforum!
l98tpi's Avatar
Default Help with LT1/LT4 Compatibility.
My LT4 bottom end came apart and toasted the crank. So have been looking for a used engine and have found one to purchase. It is an LT1 from an 95. It has just been rebuilt and heads reconditioned. My questions are;
a) Is the bottom end, short block, the same?
b) Are the heads the same except for the roller rockers? I would like to just use the heads already on the engine and put the roller rockers on.
If there is anything else I should know please let me know.
Thanks L98TPI
Old 12-20-2013, 10:48 PM
Sidney004
Sidney004's Avatar
Thanks L98TPI
The bottom end is the same. The LT4 has better heads but you would need to swap out the LT4 intake manifold as well. If you don't want to swap heads, the roller rockers will bolt on.
Old 12-20-2013, 10:57 PM
l98tpi
Max G’s
l98tpi's Avatar
So the heads and manifolds are not interchangeable? If not I will use my LT4 heads and manifold.
James93LT1
James93LT1's Avatar
http://www.grandsportregistry.com/lt1vslt4.htm
Old 12-20-2013, 11:08 PM
l98tpi
Max G’s
l98tpi's Avatar
Originally Posted by James93LT1
thanks. Answered my question. I guess we will swap heads. I am probably going to go with the LT4 hot cam or similar too.
Old 12-21-2013, 09:04 AM
93 ragtop
93 ragtop's Avatar
Not true. The factory roller rockers are a metric thread. You would need to at least change the studs as well.
Old 12-21-2013, 11:52 AM
Sidney004
Sidney004's Avatar
Thanks for correcting that, I bought aftermarket Crane Roller Rockers for my LT1.
Old 12-21-2013, 12:48 PM
Kevova
Kevova's Avatar
Grand Sport Registry lists several differences between LT4 & LT1 including Pistons, Timing set, Balancer ... etc... you could run the LT1 until you can repair LT4. You would need to watch not to over rev LT1.
Old 12-21-2013, 01:28 PM
mtwoolford
mtwoolford's Avatar
Devil is in the details; LT1 had to have EGR; LT4 did not use EGR
Old 12-21-2013, 04:07 PM
93 ragtop
93 ragtop's Avatar
One other question. What is the LT1 out of? If its anything besides a vette, ie. Camaro or Impala, it is a 2 bolt main, vs vettes having a 4 bolt main. Also, if its an impala, its cast iron heads.
Old 12-21-2013, 05:50 PM
Dr. Evil
Dr. Evil's Avatar
CI 1-2-3-4-5-6-7-8 Veteran
CI-IV AutoX Champ
CI-IV Burnout Champ
St. Jude Donor '07-'10
Also make sure its not a 4.3 Liter v8 out of a caprice.
That said, there are a lot of differences on the top AND bottom end. Crank, pistons, rings, etc. Sounds like you have most of it covered though.
Old 12-21-2013, 06:58 PM
l98tpi
Max G’s
l98tpi's Avatar
The LT1 is out of a 95 Firebird. I purchased it today and got some additional history from the owner. Short version, he purchased it from a friend who had spun a rod bearing. His plan was to rebuild it, which he did. He had it rebuilt and heads reconditioned by a performance shop which I do know of and they are reputable. After he had it rebuilt, he was working on a street rod to put the engine in. He lost interest before completing the street rod so is selling it. There were some other items such as the ECM, alt, wp.
I am going to take down to the short block and put the Heads,Cam, Intake, injectors, and etc from my LT4 onto the short block. I am going to add a road race oil pan and ATI Super Damper as well.
If anyone needs the heads and injectors and intake from the LT1, I will sale them at a good price. The heads were recon'd at time of rebuilt.
Old 12-21-2013, 08:30 PM
93Rubie
93Rubie's Avatar
Spayed 4 bolt caps on the 2 bolt LT1's are actually stronger than the 4 bolt LT1's in Corvettes. You should have no issues with the 2 bolt mains. F-Body guys run them hard all the time and they live most of the time.
Old 12-21-2013, 10:38 PM
Kevova
Kevova's Avatar
I would be willing to take that old broken LT4 to the dump for you and save you the trouble of taking the freshly rebuilt LT1 apart .....lol.....just offering
Old 12-22-2013, 02:02 PM
BrianCunningham
BrianCunningham's Avatar
Location: Boston, Dallas, Detroit, SoCal, back to Boston MA
Don't forget the timing cover and the extra sensor it holds
Old 12-22-2013, 03:08 PM
PLRX
PLRX's Avatar
Co-winner 2020 C4 of the Year - Modified
2017 C4 of Year
2016 C7 of Year Finalist
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20
The 95 has different valve covers
I have both (95 LT1, and LT4). If you read the above mentioned link, you will see both are completely different. I remember the LT4 rods were stamped "LT4". The balancer are 100% different. I'd say the block is the same on cast iron. There are many other variations like the PCV lines, and no EGR on a 96. On the EGR is an easy fix, remove the plate, and bolt the 95 EGR on it.
Old 12-22-2013, 04:41 PM
Sidney004
Sidney004's Avatar
This is a very informative thread; as I've got a trashed LT1 myself and am looking at the options available. If you've got an LT1 Camaro short block and LT4 heads and an LT4 Intake manifold; exactly what other parts would you need to make that combo work? No need to discuss the cam. Thanks!
To Help with LT1/LT4 Compatibility.
Old 12-22-2013, 04:55 PM
l98tpi
Max G’s
l98tpi's Avatar
What is the extra sensor? Is it a crank sensor? Does the 96 LT1/LT4 the first year of the crank sensor?
Old 12-22-2013, 05:52 PM
BrianCunningham
Yes and yes
Part of OBDII requirements
Old 12-22-2013, 06:35 PM
l98tpi
Max G’s
l98tpi's Avatar
Yes and yes
I hope the 95 LT1 crank will work. Anyone know? If not I wonder if I can make it work or can we disable crank sensor input from the ecm? Need some big help with this one.
Quick Reply: Help with LT1/LT4 Compatibility.
