Part #'s (Master & slave) clutch cylinders
Anyone know the correct AC Delco part numbers for the clutch master cylinder, and the clutch slave cylinderfor a 96 grand sport?
Sledge_78
Sledge_78
*** Now that you've mentioned a year here's the ACD catalog BUT you need to understand that unlike some "parts" that have both GMSPO numbers and ACD numbers - clutch hydraulics aren't the same as GMSPO "product". The clutch hydraulics have never been offered in ACD to be duplicates of the GM/OE.
Here the catalog and the rest is just simply drop-downs:
http://parts-catalog.acdelco.com/cat...log_search.php
Received 3,043 Likes
St. Jude Donor '05
Didnt think you could still get Delco stuff anymore. That would be a find
For starters there are various years? Is there a particular reason you've chosen the ACD product? There's ACD catalogs all over the Internet.
DORMAN CM39763
DORMAN CS36001
Compliments of LD85's recommendations a while back. But if you're going for factory correct, disregard.
I believe RockAuto has the Delco brand selections for these when you do a search for a specific year. Doing a ZF conversion and I ended up going with Dorman brand master and slave after reading a little about the cast iron pieces being sturdier.
DORMAN CM39763
DORMAN CS36001
DORMAN CM39763
DORMAN CS36001
