Lt1 cam reground to LT4 hot cam
Old 11-29-2013, 01:21 PM
Bornwild
Support Corvetteforum!
Bornwild's Avatar
Default Lt1 cam reground to LT4 hot cam
Hi Everyone, Happy Hollidays. I have a cam that was sent to Delta camshaft to be ground to a LT4 Hot Cam? It is stamped GMPT BC 15-242 pn the inside of cam between lobes. The 17th lobe is ground down to hardly anything. I believe that this is the fuel lobe? Any info would be helpfully. Thanks John
Old 11-29-2013, 01:22 PM
Bornwild
Bornwild's Avatar
Default Cam pics
Pics
Old 11-29-2013, 01:24 PM
Bornwild
Bornwild's Avatar
Default Last cam pic
The last cam pic!
Old 11-29-2013, 01:35 PM
cv67
cv67's Avatar
Received 3,043 Likes on 2,602 Posts
St. Jude Donor '05
yes thats for the fuel pump eccentric.
Old 11-29-2013, 01:53 PM
Bornwild
Bornwild's Avatar
Default Fuel pump lobe
So with that being said! Is this going to work with the LT4 SBC corvette engine? I think that the cam was out of a Z28 1995-96 or maybe a Impala? Thanks John.
Old 11-29-2013, 01:58 PM
cv67
cv67's Avatar
St. Jude Donor '05
Sure they used electric fuel pumps
Old 11-29-2013, 06:16 PM
Bornwild
Bornwild's Avatar
Default Cam
O.K. Thanks for you help! Happy hollidays John.
Old 11-29-2013, 07:48 PM
MrWillys
MrWillys's Avatar
I would only like to say one thing here. I'm under the impression they can redo duration and lift, but cannot change the lobe seperation angle? Therefore, it is not the exact grinf of the hotcam, because they have a different lsa.
Old 12-01-2013, 04:11 PM
GREGGPENN
GREGGPENN's Avatar
C4 of Year Winner (appearance mods) 2019
How can they increase duration? An LT1 cam is something like 203/207 while a hotcam is longer with more lift. 218/228
Old 12-01-2013, 04:30 PM
MrWillys
MrWillys's Avatar
I believe they do it by reshaping the lobe making it slightly smaller, but it's just a guess. Therefore, the valve lash makes up for it.
Old 12-01-2013, 08:47 PM
DanielRicany
DanielRicany's Avatar
Better off just buying the cam. I imagine they aren't too expensive.
Old 12-01-2013, 08:52 PM
NuckinFutz93
NuckinFutz93's Avatar
I don't know about GENI &II engines, but on GenIII&IV, you have to run longer pushrods to achieve the lift.
Old 12-01-2013, 09:06 PM
DanielRicany
Quick question, not trying to hijack this thread but what gen is the L98?
Old 12-01-2013, 09:08 PM
bassackwards
bassackwards's Avatar
I believe this just corrects the geometry on the rockers. The cam and the rocker ratio control the lift.
Old 12-01-2013, 09:32 PM
MrWillys
MrWillys's Avatar
Daniel, gen 1 is 1955 through about 2003, or 2008 in boats. gen 2 is 91 through 97 LT1 (gen 2 was a gentle massage and many parts still interchange), and the Gen 3, 4 is 1997 and newer, and is Waaay different. Therefore, the L98 is Gen 1.
Old 12-01-2013, 09:41 PM
DanielRicany
Okay cool thanks. I was hoping my pushrods could have been part of the reason that I am not getting full power out of my cam but I guess it's just my stupid iron heads. Haha.
To Lt1 cam reground to LT4 hot cam
Quick Reply: Lt1 cam reground to LT4 hot cam
