bore and stroke question
Old 10-22-2013, 05:29 PM
TheMTazzi
TheMTazzi's Avatar
Default bore and stroke question
hey guys just a quick question, how much of a bore and stroke can i go with with a regular ls1 without changing cam, pistons exc.
Old 10-22-2013, 05:52 PM
vetteoz
vetteoz's Avatar
If you bore you need new pistons , if you stroke you need new pistons
Old 10-24-2013, 05:10 PM
TheMTazzi
TheMTazzi's Avatar
ooo ok, idt thatll be too expensive, do you now how much theyll cost? and also if you know what kind i should buy that will be helpful. also, if this helps, since i am running the stock cam, how big i should go (373,383,402, exc.) without changing it?
Old 10-25-2013, 12:34 AM
vetteoz
vetteoz's Avatar
Depends what you are doing , boring , stroking or both; 3 different pistons ?
You probably wouldn't use the stok cam if you stroked it
In any case seeing it is a LS1 question ,you should be asking the LS1 owners here
http://forums.corvetteforum.com/c5-tech-1/
Our 84 - 96 cars don't have those engines
Old 10-26-2013, 11:36 AM
TheMTazzi
TheMTazzi's Avatar
i fail, i do not know how i ended up on the c4 forums hahahahha srry bought that my work computer sucks
To bore and stroke question
Quick Reply: bore and stroke question
