L-83 Performance Heads?
I am looking at getting some performance heads to address the flow problem with L-83s. I am going to get a different Crossfire custom intake and probably some 2inch TBs or get mine bored and some 90lb injectors. Anyone have any suggestions/experience with new heads on an l-83?
Pro Mechanic
and most aftermarket replacements
Vortec heads have only 4 bolts and require a special Vortec only intake which I don't believe you will find a CFI version of
Your heads are regular 6 intake bolt SBC heads , the same as any cast iron SBC heads from '55- '86 ,the Vette alum heads from L98's
I replaced the 624 heads on my l83 with aluminum pieces from Edelbrock The original heads have 76cc chambers and the Edelbrock heads have 70cc so the compression will bump up a little depending on the head gasket used. I ended up using a victor .026 head gasket. These heads also allow valve lift of .575 nice springs and valves
