sparks shooting around front side of starter
Old 09-29-2013, 12:36 AM
85corvettec4
85corvettec4's Avatar
Default sparks shooting around front side of starter
sparks shoot out around the front side of the starter. i got down there and tightened all the wire connects and its still happening, this si after i put the tpi on after a previously carbed. it worked fine before i tore it down
Old 09-29-2013, 12:55 AM
xrav22
xrav22's Avatar
Hey there keep in mind almost all wires are charged on this system, they get grounded by ECM then they complete the circuit, so if you forgot or there is a rpm, distributor ,alarm, knock sensor wire hangin against the block it will spark.
Look for a unconnected wire from the hvac system or something.
Quick Reply: sparks shooting around front side of starter
