Fan comes on at 158 degrees
Old 09-19-2013, 06:55 PM
92polo
92polo's Avatar
Default Fan comes on at 158 degrees
I had quite a bit of work done recently. ARH headers, plugs, wires, o2 sensors and hyper chip. Now I get a code 26 and the fan comes on at 158 degrees. Any ideas would be helpful. I will be checking the 3 sensors related to code 26 this week end, but the fan has me puzzled why is engages at 158 degrees instead of 228 degrees.
Thanks in advance
Old 09-19-2013, 06:56 PM
92polo
92polo's Avatar
Sorry, brain fart, 92 LT 1 automatic
Old 09-19-2013, 07:14 PM
vetteoz
vetteoz's Avatar
Have you confirm your temp gauge is accurate by another means like a thermo gun?
What is the fan setting supposed to be on the Hyper chip?
Now I get a code 26
http://forums.corvetteforum.com/1565906743-post5.html
http://www.ls1lt1.com/forum/514946-post2.html
Old 09-20-2013, 12:29 AM
Cliff Harris
Cliff Harris's Avatar
The second link is the most accurate, but still not right. If there is a quad driver fault the ECM/PCM will set error code 26. It does this if it detects too much current in one of the 4 outputs. Generally that means that something is shorted, either a relay or solenoid or the wiring. Unfortunately it doesn't tell you which one is bad.
The first step is to determine which 4 things are controlled by that quad driver. Then investigate those guys (and the wiring).
Feel lucky. Earlier cars didn't even have this error code available.
Old 09-20-2013, 07:04 PM
92polo
92polo's Avatar
Thanks for the input. I was told today the fan setting on the hyper chip is set at 160 degrees, so I guess that is ok. I will be testing the solenoids tomorrow and hope I can diagnose the problem. Today the AC went out again and the buttons started flashing. The AC was also just reset a week ago while in the shop. Any ideas or could this also be related to the code 26?
Old 09-20-2013, 07:34 PM
vetteoz
vetteoz's Avatar
Have you changed the thermo stat to reflect the new fan operating temps
Old 09-22-2013, 09:09 PM
92polo
92polo's Avatar
I found the problem. I disconnected the battery and changed the 2 solenoids under the fuel rail covers and still had the service engine light come on but not until the fan kicked in at 190 degrees. So I started looking at every connection under the hood. Boy do I feel stupid. I found a connection to something located under the ASR on the drivers side that the mechanic who installed the headers did not reconnect. As soon as I plugged it in and started the car the AC works and the service engine light never came back on. I guess you have to check everything any time you have someone work on the car for you. Thanks for everyone's help.
Old 09-22-2013, 09:49 PM
pkincy
pkincy's Avatar
It is the mechanic that should feel stupid. Glad you got it figured out.
To Fan comes on at 158 degrees
Quick Reply: Fan comes on at 158 degrees
