Go Back   Corvette Forum > C4 Corvettes, 1984 - 1996 > C4 Tech/Performance
Register Forgot Password?
Register Albums Search Today's Posts Mark Forums Read FAQ
Search
C4 Tech/Performance
L98 Corvette and LT1 Corvette Technical Info, Internal Engine, External Engine Sponsored by
J&D Corvette
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 09-12-2013, 02:55 AM   #1
lozer
CF Senior Member
Default New 383 eating distributor gear!!!!
SO 89 l98 383 with lpe 219 cam just pulled the dist and noticed some wear on one side of the dist gear. Checked runout on the shaft and found it to be .08 in (the runout is right at the wear point)
So whats a good affordable replacement or can i get away with just swapping out the shaft ( i have an old one floating around that i will check for straightness.
O and im pretty sure the shaft was bent from a massive backfire from before the engine was rebuilt. (no really this **** backfired so hard i had to replace all my exhaust gaskets)
lozer is offline   Reply With Quote
Old 09-12-2013, 06:30 AM   #2
vetteoz
CF Senior Member
vetteoz's Avatar
Does the material the dist gear is made of match that required by the cam ?
vetteoz is offline   Reply With Quote
Old 09-12-2013, 07:20 AM   #3
WW7
CF Senior Member
WW7's Avatar
I believe the Lingenfelter 219 requires a melonized gear to be used... You could always get a composite gear which will work with any cam material ,plus they never wear out....WW
WW7 is offline   Reply With Quote
Old 09-12-2013, 07:43 AM   #4
kevingib
CF Senior Member
kevingib's Avatar
Quote:
Originally Posted by WW7 View Post
I believe the Lingenfelter 219 requires a steel melonized gear to be used... You could always get a composite gear which will work with any cam material ,plus they never wear out....WW
+1 - The gear you have probably doesn't match the cam selected.
kevingib is offline   Reply With Quote
Old 09-12-2013, 08:59 AM   #5
lozer
CF Senior Member
Im getting a new Gm Melonized to go back in with the new distributor but it died due to a bent shaft. the runout is .08 or .1 in now if i put some tape over the toothed part and pull the runout there its smooth with almost no runout. Therefore the cam ate the bent part out. (why the gear was only half eaten) So I just need to know what a good replacement distributor.
Old 09-12-2013, 10:27 AM   #6
383vett
CF Senior Member
383vett's Avatar
Quote:
Is your cam gear billet or a pressed on iron gear?
383vett is offline   Reply With Quote
Old 09-12-2013, 10:37 AM   #7
lozer
CF Senior Member
Cam looks to be pressed on iron (blackish) and its a 74219 Accell.
Old 09-12-2013, 11:26 AM   #8
383vett
CF Senior Member
383vett's Avatar
In that case, you should be able to use an iron (stock) gear. The runout must be heating you distributor gear. Hopefully the cam is ok.
Old 09-12-2013, 02:21 PM   #9
WW7
CF Senior Member
WW7's Avatar
Quote:
Here is an iron distributor gear that will mesh with your iron cam gear...Here's what the details say..... "Iron gears are designed for iron camshafts or roller cams with existing iron gears".............I have a pressed on iron gear also, and this is the dizzy gear Im using....WW
http://www.jegs.com/i/Accel/110/3210...FUVp7Aodgn4AzA
Old 09-12-2013, 06:04 PM   #10
Calderone
CF Senior Member
Calderone's Avatar
i got the 219 cam from LPE (CompCams do their grind) and i've been using the stock
dist gear with no problems at all over this years. I didn't want to change it.
Calderone is offline   Reply With Quote
Reload this Page New 383 eating distributor gear!!!!
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
