Anybody using Hawk brake pads?
Old 08-24-2013, 09:33 AM
Midnight 85
Midnight 85's Avatar
Finalist 2020 C4 of the Year - Modified
Default Anybody using Hawk brake pads?
I recently put the Hawk HPS pads on my car, the ones in the blue box. I am not real happy with how much pressure I have to use to apply the brakes. I have a new booster & master cylinder also so I need to know others feelings about these pads so I can know if I need to go looking for a problem possibly in the calipers. I also have the DRM bias spring in the master but that was in the old master also. Even with my mild cam I believe I have sufficient vacuum to operate the brakes properly.
Old 08-24-2013, 09:57 AM
kimmer
kimmer's Avatar
C4 of the Year Finalist
Hawk is a top notch pad, try bleeding your lines. Did you bed them properly?
Old 08-24-2013, 10:40 AM
Daredevil95
Daredevil95's Avatar
I always use Hawk,,,for all my cars. There a good brake pad IMO,
Old 08-24-2013, 11:08 AM
Calderone
Calderone's Avatar
i love them! re-bleed and try
Old 08-24-2013, 01:08 PM
Midnight 85
There is no pedal pump up, it stops in the same position every time but I will try bleeding them again.
Old 08-24-2013, 01:22 PM
tequilaboy
tequilaboy's Avatar
I bet your new booster is leaking or already cracked.
Old 08-24-2013, 01:25 PM
QZRBLU
QZRBLU's Avatar
2017 C4 of Year Finalist
If you installed these pads on used rotors or if you failed to totally clean the rotors before bedding, you may have to use them for 50-100 miles before you get good braking. The slight grooves cause terrible braking with new pads on used rotors. I have Hawk performance ceramics on my '90 and they stop GREAT with little pedal pressure. I used a disc sanding pad on my portable drill motor to burnish all 4 original rotors before bedding.
Mick
Old 08-24-2013, 02:36 PM
Midnight 85
I've got the same feeling, take a look at the pic I posted below.
Mick
Rotors were turned just enough to clean & true them up. The new pads were bedded properly and I just got back from a 950+ mile trip. The car will stop in an emergency situation with no problem but I really have to stand on them. The pic below shows a pattern that is on the rotors, I just washed the car so the rust made a good contrast so the pattern showed up better.
[IMG][/IMG]
Old 08-24-2013, 02:39 PM
Midnight 85
Forgot to mention, no air in system, I just bled them again. Engine vacuum is rock steady at 15, maybe I need a different vacuum canister? The stock one is good, holds vacuum forever.
Old 08-24-2013, 03:02 PM
QZRBLU
QZRBLU's Avatar
Looking at that rotor, I'm guessing the new booster is leaking internally.
Mick
Old 08-24-2013, 03:25 PM
Midnight 85
I was afraid of that, but look on the bright side, I get to do that wonderful job again. *&%^#$@
Old 08-24-2013, 11:32 PM
Midnight 85
Broken check valve!! I started the car for a few minutes then shut it down. I went to pull the check valve out of the booster to see if there was any vacuum and half of it came off in my hand, the other half was still in the grommet. I now have good brakes and the engine is even running stronger. I'll be adding this to my ever growing list of new parts that are broken or just won't work right out of the box.
Old 08-25-2013, 12:17 AM
QZRBLU
QZRBLU's Avatar
Congratulations!
Mixk
Old 08-25-2013, 10:42 AM
Matthew_EOD
Matthew_EOD's Avatar
Glad you found the problem. Not stopping really sucks.
Old 08-25-2013, 12:48 PM
Midnight 85
You are so right, especially since I had a VERY close call just before I had them fixed. If the car did not handle the way it does I would have centerpunched some old hag who turned in front of me.
To Anybody using Hawk brake pads?
Quick Reply: Anybody using Hawk brake pads?
