Wipers
Wipers
ok i have no delay wipers or they wont park once they are on even with the switch turned off till i shut of the key, low and high work fine. washers work also but they stay on after i use the washers.
The switch is probly dirty. You can carefully separate the body of the switch and clean up everything inside, put in a little dielectric grease on the contact areas and reassemble. Really not that hard.
Give it a try. If the switch is already phukd, you aint out nothin if you break it.
On my 93 I ended up having to replace the wiper motor cover and the multi-function switch in the steering column. Got both parts from Corvette Central (about $170.00 for both) and now wipers work like they should. Installing the multi-function switch was the hardest part. Had to take steering wheel off, airbag, etc. Took about 3 hours to replace the switch.
