Go Back   Corvette Forum > C4 Corvettes, 1984 - 1996 > C4 Tech/Performance
Register Forgot Password?
Register Albums Search Today's Posts Mark Forums Read FAQ
Search
C4 Tech/Performance
L98 Corvette and LT1 Corvette Technical Info, Internal Engine, External Engine Sponsored by
J&D Corvette
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 07-27-2013, 05:51 AM   #1
ladystoy69
CF Senior Member
ladystoy69's Avatar
Default cooling fan relay (hot all time) wire source?
ok figured i would figure out just how badly someone messed up the cooling fan wiring when they bypassed it to manual control.
what i found was that they must have had a problem first and band-aided it with a switch as i found the main fan relay hot all the time wire goes nowhere. i see where the second fan has its fusable link and pretty sure that is same general area the main fan relay should have its fusable link as well, but i can only fallow the main fan relay (hot all time) wire to about where the fuseable link should be but no link or even a stray wire there at all.
so my question is on a 85 corvette where do these hot at all times wires for the fan relays originate? looks as if they go into the firewall, so is there source under the dash? ran out of tracing time so i just figured asking might be quicker.
thanks in advance
ladystoy69 is offline   Reply With Quote
Old 07-27-2013, 07:29 AM   #2
AGENT 86
CF Senior Member
AGENT 86's Avatar
On my 86, there is a red wire molded into battery terminal. A few inches from terminal, it splits into 2 wires to feed both relays.
AGENT 86 is offline   Reply With Quote
Old 07-27-2013, 02:00 PM   #3
383vett
CF Senior Member
383vett's Avatar
The fan relay is right next to the battery. Just run a hot wire from the + battery terminal and throw in a 15 amp fuse on the way to the relay.
383vett is offline   Reply With Quote
Old 07-27-2013, 07:32 PM   #4
ladystoy69
CF Senior Member
ladystoy69's Avatar
ok thanks guys... odd i cant see where they cut them from but that helps greatly thanks
Old 07-27-2013, 08:32 PM   #5
SunCr
CF Senior Member
If I remember this right, the early C4's were fed from a lug at the Starter, so you might look there if you want it Stock. Sometime around '87 or '88, a Junction Block was used which was located behind the Battery.
SunCr is offline   Reply With Quote
Reload this Page cooling fan relay (hot all time) wire source?
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
