Go Back   Corvette Forum > C4 Corvettes, 1984 - 1996 > C4 Tech/Performance
Register Forgot Password?
Register Search Today's Posts Mark Forums Read FAQ Vendor Directory
Search
C4 Tech/Performance
L98 Corvette and LT1 Corvette Technical Info, Internal Engine, External Engine Sponsored by
J&D Corvette
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C7 Parts & Accessories
C6 Parts & Accessories
C5 Parts & Accessories
C4 Parts & Accessories
C3 Parts & Accessories
C2 Parts & Accessories
C1 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 07-24-2013, 04:35 PM   #1
Cajaw Jordan
Junior Member
Default 1985 Manual Oil Pressure Check
How difficult is it to do a manual Oil Pressure check on a 1985? I know the approximate location but cannot find it....Passenger side block, near(?)...can it be accessed without tearing the car apart..? My Oil pressure is dropping to as low as 0.....I do have and ongoing low idle problem. I am not sure I believe the digital dash or whether I am having a failing motor...although.....I do not believe so....at 0psi...this engine show "blow" after just a moment or two.....at high rpms the Oil Pressure goes above 50 and climbs in linearity to RPM.....any suggestions on a troubleshooting procedure...I know there is more than the sending unit....i.e. pump, pressure release valve, clogged returns etc........too many to think about without headache!
Chris
Cajaw Jordan is offline   Reply With Quote
Old 07-25-2013, 01:38 PM   #2
rklessdriver
CF Senior Member
rklessdriver's Avatar
Quote:
Chris
2 places....
(1) DRIVERS SIDE just above the oil filter is a plug you can remove to check oil pressure.
Click the image to open in full size.
(2) Behind the intake manifold... this is where the factory oil pressure sensor/sendors are located.
Will
rklessdriver is offline   Reply With Quote
Old 07-26-2013, 07:58 AM   #3
Cajaw Jordan
Junior Member
thank you guys for the great instructions!
Old 07-26-2013, 07:59 AM   #4
Cajaw Jordan
Junior Member
thank you for the great instructions
Reload this Page 1985 Manual Oil Pressure Check
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Check gauges light and oil pressure blownrunner C4 ZR-1 Discussion 4 06-02-2014 01:18 AM
Intermittent Low oil pressure.. violinsib C4 Tech/Performance 2 03-20-2014 10:24 PM
LOW OIL PRESSURE to ZERO OIL PRESSURE and NOW ENGINE RATTLE Ahmer C6 Corvette General Discussion 100 02-14-2014 04:55 PM
HELP no oil pressure gauge wired1141 C4 Tech/Performance 2 10-16-2013 02:37 PM
No or Low oil pressure rmslusk C3 Tech/Performance 6 01-29-2013 09:18 PM
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
