You might want to make another choice.
I started a thread yesterday about my noisy Professional Products fuel pressure regulator. It got worse today and was making all kinds of noise so I called Prof. Prod. I explained my problem and the "tech" said, "well, you know,, fluid does make noise when it is going through a pipe" I knew right then and there he wouldn't be getting a Christmas card from me. He told me he had never heard of such a thing, no offer to look at it or anything. I told him I planned on taking it apart to see what I could see. The reason I told him is to see if he would say no, it will void the warranty but instead I get, "it's yours, do what you want with it. I wanted to tell what I would LIKE to do with it but I just hung up on him, I must be getting old. This is the second item I have bought made by Prof. Prod. and it's the second one to not work right. Just thought I would post this for all to see, in case you were considering buying a PP product.
Mine is completely different from a tpi style fpr. It works by the same principle though and I have had it apart and cannot see a thing wrong, BUT, when I put it back together it was quieter!
Professional Products is the same crappy company that sold defective dampers for several years. They delaminated.
They also made aluminum intake manifolds that did not fit unless you ground material off of it so it would sit down properly on the heads. I know this first hand. This is what I get for trying to save a little money. To be honest, the azzhole I talked to pizzed me off more than the regulator problem.
I think I am going to try one of Summit's own brand regulators, anyone have any experience with them? I'm also considering FAST and AEROMOTIVE. Anyone have any other suggestions??
Set it to the pressure you want and you are good to go, i have no noises from my fuel pressure regulator and the car loves 45 to 50 psi fuel pressure.
No need to spend the money on an adjustable fuel pressure regulator, just disassemble the standard fuel regulator drill a hole and tap the cover fit a screw and spring to keep it from moving under vibration or have a nut that can be locked when the pressure has been set.
For you and I it offered up an alternative to consider!
Some of Pro Products stuff is OK and a good deal for the $$$ but some of it is pure junk. Sometimes we find out the hard way "which is which".
Will
You know, I was thinking the same exact thing. I had already changed my mind earlier this morning and decided on the FAST regulator unless somebody has some negative info on them. My car does is not raced so please don't suggest one of the high dollar units. Thanks rklessdriver for confirming my suspicions.
To those with suggestions on using the stock fpr, thanks but those days are long gone for my car, I'm sure your comments have turned on a light bulb for others and that is what it is all about.
I've got another question about this noisy regulator. My car was running absolutely beautiful until this excessive noise started, at that time my hesitation when revving returned. This happened from the time of shutting it off one night and re-starting it the next day. Could it be possible for the regulator to show good pressure on the gauge yet still have too much gas going into the bypass which is, I think, where the noise is coming from. I wear two hearing aids so pinpointing this noise is not possible. If the fuel is bypassing more than it should, this would cause my hesitation if I am correct. I'd like to hear what some of you experienced guys have to say about this.
Midnight, the simple solution would be to turn off the hearing aids when you drive. You know the old question about a tree falling in the forest... If your car is hesitating and your fuel rail pressure is ok, you don't have a fuel delivery problem unless your injectors are boogered up.
I have an Aeromotive unit on my LT1 and looks nice and easy to adjust. I did have problems at first and was sent another new unit and they paid for the return (JEGS). The only thing I may yet change is rotating the cover so my vacuum line is in a different direction for my hose routing for the unit.
Midnight 85: I have an Accel adjustable fuel pressure regulator that I bought for a Fiero I had....quite some time ago...never used it. I wonder if it would fit your engine....as it sure is not going to fit anything I have now.
Would you be interested in it? If so I can dig it out of the box and get the part number off of it...perhaps take a picture or so. This was for the V6 Fieros 1985 to 1988....so the application year is the same.
Anyways let me know if interested.
I have two votes for Aeromotive but none for the FAST so I may change my mind again.
