180 Degree Thermostat?
If I install the 180 T-Stat on my 88 Vette L98, will it mess with any of the sensors? I'd like to have the engine run a cooler, right now it runs between 192-200 degrees.
Thoughts on doing this?
Possible though not probable.
I'm thinking the ECM causes the fans to run constantly when in fault mode. I don't know the various faults that would cause it off the top of my head. The ECM itself could be "bad" or have a connector problem. I'd have to consult the manual. Others, more adept at this issue, will likely chime in.
To answer your original question, lowering thermostat temp will not cause fault codes.
The check engine light has not come on except for when I forgot to plug the Mass Air Flow sensor back in. For the system to be run in fault mode would cause a check engine light correct?
I am thinking the previous owner had a relay issue and just hard wired the damn fans...
You make a good point. The only time I've gotten the fans-on condition is while logging (scans). I don't recall a "check-engine" light being present. But, I'm plugged into the ALDL connector. I wonder if it's possible there's a piggy-back (or jumper) in your ALDL connector? This can be used to flash codes to the info center IIRC.
Also, relays are typically used to trigger the high-power supply necessary to drive accessory components. "Hard-wiring" around a relay doesn't make sense either. I also can't understand why anyone would want the fans running 24/7.
Yeah, that's my next project this week... I actually thought it was weird the fans ran all the time, but did not pay much attention to it. Of course I have only driven the car a few times to work which is 2 miles down the road.
After further review:
There are two fans, 1 mounted on the front of the radiator and one mounted behind the radiator.
If I unplug the fan relay, the fan in the engine bay will shut off however the other fan stays running. The instant I plug in the relay, both fans run, non stop.
The check engine is not lit and the engine runs good leading me to think the system is not in limp mode. Any suggestions?
I have an 88 and a 180 thermostat and everything runs fine with no codes.
The main fan is commanded on by the ECM at 228F, and I can't remember at what temp it commands off. When I installed the 180 thermostat my tuner changed the command on to 210 and off at 185.
The aux fan is controlled by a temp switch in the drivers side head.
Both fans are switched on and off through a relay and neither should run at all times. The aux fan brushes wear out quick too. The PO either bypassed the ECM and relays or both relays are stuck closed.
Get the FSM, it has the wiring diagrams.
Ok, the 2nd relay is located on the radiator housing, unplugged that and it shuts off the other fan. So they are not hard wired...
Chances of both relays being bad? Slim I think. So is it a temp sensor in the head or the ECM causing the fans to run?
So the secondary for fan #1 is the AC - fan #2 must be the temp sensor between plug 1 and 3 on the head.
So this means the chances of both secondary options being bad is slim and it is more then likely an ECM issue.
I guess my next step is to unplug the battery, plug it back in and have the ECM scanned.
I did find this:
http://www.chiltonlibrary.com/Conten...aspx?ca=Repair
If anyone can read the wiring diagram for a 1988 Corvette L98 lol
