Exotic Muscle Coil Over install issue---Pics inside
Im installing my coilovers on my 1996 corvette. They are hitting the shock brace. Pics are worth a million words so tell me what you think.
That's a known issue and the tower requires being spread somewhat. I believe it's even covered in their instructions. Regardless it is a known issue and isn't much to overcome but it would certainly have been good to have known going in. I believe you bought this package from a private individual OR was it a direct purchase from them.
Co-winner 2020 C4 of the Year - Modified
2017 C4 of Year
2016 C7 of Year Finalist
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20
I've seen few thread about those. They widened the tower with vice grips. I'd use a hammer.
Looks like a crescent wrench could easily widen the flange.
2017 C4 of Year
A 1" or so piece of 1/4" bar stock and the crescent wrench might give a more presentable spread and the deeper the jaw of the crescent the more presentable also.
As stated above you have to flare out the side edges of the upper shock mounts. I did this with an adjustable wrench, which worked quite well. As I noticed once I had everything hooked up and weight was put on the front suspension it actually drew the coilover away from the pocket and gave more clearance. So it may look bad now with no weight on the suspension but it changes after you have the car together and weight on it.
You would think that would do but I believe the material of the tower is a little to stout. I believe a friend tried it with those and he had a leverage issue and I believe the clamping wasn't effective. It's been a long while and I believe that he did as I mentioned to do it. The bar stock and maybe he used a "pair" of crescent wrenches. I believe his crescent was bought just for that and it might have been a 14" or so. It wasn't the normal crescent found in most boxes.
2017 C4 of Year
I don't know if all coilover set-ups for C4 need modification; I do know these ones, QA1, and others that have been done here in the CF required relocation of sway bar, frame cutting, frame grinding, and other little things.
I had to move my sway bar towards the front for my aftermarket sway bar to clear the coilovers. To do that I had to create access thru the frame.
PLRX- I'm certainly not shy about modifications , but structural integrity, especially concerning modifying the minimal material around the shock tower, doesn't sound appealing to me. I guess I wasn't aware of the modification needed to the tower frame to get a coil-over to work.
I was aware of the sway-bar relocation, in which case structure isn't compromised.
Yup just found out that my sway bar end links wont work with my aftermarket sway bar. Ill get a hole saw tomorrow. Sigh..... only thing I have left unmodified is my brakes. Just need to finish the c5 upgrade. I got the parts but they are on the east coast.
Van Steel Coilovers;
http://www.vansteel.com/index.cfm?fu...&SubGroup=1972
Heim Jointed Sway front bar links;
http://www.guldstrand.com/scripts/pr...?idproduct=142
