what spark plug to use lt1 94
hey everyone just wondering what plug I should use for my 94 lt1?
is the rapid fire plug a good replacement for the stock ac delco plug
I just bought my car a while ago and just finished putting in a new msd opti spark as the factory one went bad when the water pump leaked. so that stuff is all new and out of the way. but I would like to replace the plugs and wires cause I don't know when they were last changed.
1 Post
I just bought AC Delco 41-906 platinum plugs and Delphi 7mm wires for my Admiral off of RockAuto.
I have NGK copper plugs with Taylor Spiro wires on the Rose and have zero complaints.
I went with the Delcos and Delphi wires because they were on sale at the Rock. I think I paid about $45 total for the plugs and wires.
I've pretty good luck with the Rapidfires and NGK's. The important thing to remember is proper gap and correct temperature rating. Don't fall for all the multi electrode things like v-power or +2 or especially +4 gimmicks.
And to make the wire replacement job easier I also removed and replaced my water pump" which was leaking water a fact I didn't know until the pump was removed for inspection" you might also want to get new spark plug wire separators.
thinking ill go with the ngk and tayler wires what should I gap them at. thanks to all for the info I have learned so much about my 94 from this site great people and more then willing to help even if its a ongoing question.
I have the Taylors too but they don't fit in the stock wire looms so you'll have to rig something up. I used nylon wire ties to tie them off to various places. Not pro but my '94 is a DD not a show car. The fatter wires are a bitch to route to the opti on the left side.
