Heres a head sctratcher...
The right turn signal indicator on my dash is constantly on(solid, not blinking)
My left signal works fine
The right signal does not work, yet the indicator is still on.
The hazards work fine, and the indicators on the dash blink as they should
Thoughts?
Thoughts?
Nope, all the bulbs are functional.
Where is the right side signal flashed located on a 1988?
where exactly would I look for these issues? (when I look at random wires I tend to go cross-eyed)
If it is wire related, would I still hear the clicking sound coming from the flasher? Because there is no sound coming from it.
I actually had this same problem on another car that I had bought. Had the problem when I drove it home. Turned out to be the wrong bulb had been installed in the socket. An incorrectly installed bulb will cause the same thing, but if the bulbs haven't been tampered with when the problem started, then I'd bet my mortgage its a bad ground / corroded socket. Be sure to check the side markers, too.
I just had this problem last month. It was the ground wire contact where it plugs into the socket. I wiggled it around and it started working. The contact on the end of the wire is bent to provide pressure against the contacts inside the socket. Mine had broke in half. I bought a new socket at Pep Boys for about $10 and cut off the old one and wired in the new one. Problem solved! 30 minute fix. Hope this helps.
