FX3 Struts Needed
Old 06-07-2013, 10:06 AM
89 Vett
89 Vett's Avatar
Default FX3 Struts Needed
I've seen this topic come up before but couldn't locate the right info when I searched for it.
I have a 1989 with the FX3 active ride control. The shocks need replacing and the shop says they are no longer manufactured and want to convert it to a standard setup.
Is my only option to located some used shocks?
Old 06-07-2013, 10:15 AM
1991Z07
1991Z07's Avatar
I have a 1989 with the FX3 active ride control. The struts need replacing and the shop says they are no longer manufactured and want to convert it to a standard setup.
Is my only option to located some used struts?
Bilstein still rebuilds the shocks...somewhere I have their number to call.
I think you can also find it on their web site. If you send 2, you may as well send all 4 because chances are they are ALL the same age. Consider the other 2 on borrowed time.
Old 06-07-2013, 10:55 AM
89 Vett
89 Vett's Avatar
Called and left a message with Bilstein in North Carolina. Anyone have a better contact?
http://www.bilsteinus.com/about-bilstein/contact/
AFTERMARKET & MOTORSPORTS – EAST
ThyssenKrupp Bilstein of America
293 Timber Road
Mooresville, NC. 28115-7868
1-704-663-7563
Old 06-07-2013, 11:34 AM
92ragtop
92ragtop's Avatar
2019 C4 of Year Finalist (appearance mods)
2015 C4 of Year Finalist
FYI, Vettes do not use struts. They have shocks. You might think there're the same thing, but they're not.
Old 06-07-2013, 11:56 AM
tahoemedic
tahoemedic's Avatar
some of the aftermarket vendors have been selling new or remanufactured versions. try Mid America or Ecklers. Mine have been non-functioning for a few years. The problem is the "pot-metal" sproket on the top of the shock crumbles after a while and the computer can't adjust the shock. I'm going to forge some new ones out of aluminum and see if it fixes the problem better.
Old 06-07-2013, 01:00 PM
adtbrown
adtbrown's Avatar
That little socket can be replaced. I had one break on mine. I bought a new one from Volunteer Vette and replaced it. Been working ever since. Cheap and easy fix. A rebuild on all 4 shocks would be nice, but it's about $250 per shock.
Old 06-07-2013, 01:13 PM
89 Vett
89 Vett's Avatar
Yeah, Bilstein called me back and it's $210ish per shock + shipping. I went ahead and paid Corvette America $370. It's definitely more, but Bilstein can't cross ship so it would add a week and a half to the time in the shop.
Old 06-07-2013, 03:00 PM
dzim
dzim's Avatar
Default FX3 Bilsteins
I bought new Bilsteins for my 1994 ZR-1 which is equipment with the FX3 option this March from http://www.eshocks.com/bil_veh.asp?M...=All&SubChar=Q. You may want to check them out. If you do, make sure you buy the shock mounting kits also as they do not come with the shocks.
Dale Zimmerman
Lincoln, Nebraska
Old 06-07-2013, 03:52 PM
89 Vett
89 Vett's Avatar
I already ordered from CorvetteAmerica, but the nice guys there price matched for me.
To FX3 Struts Needed
Quick Reply: FX3 Struts Needed
