1990 - funny rear right wheel sound
Hi, with nothing turned on , when I roll up to a red light, I hear a little sound in the rear wheek, each revolution it sounds like a tiny rubbing sound, maybe a wheel bearing, is that what you think it is?
How serious is this?Just srarted and I hardly drive it, sunny days only!
Also, what is this, cutting the louvers with regards to increasing air intake?I have been told not to bother with a k N Air filter or vortex intake, or change the throttle body, just cut louvers.does that end up increasing the chances of water coming into the filter?
MZee
MZee
yes
VERY
no
FWIW
the K&N will save you money since you wash it and re-use it. I throw mine in the washer sometimes...
K&N breaths better. Cutting every other bar off the air filter lid will let more air thru. the Nose has a series of baffles to keep water out.
WHo-ever told you not to bother with some of this was not a Vette owner...the K&N pays for itself and DOES help with air flow.
A 52mm TB on a L98 when you do exhaust at the same time WILL get you a quicker revving engine.
The so called cold air intake is pure gimmick...stay clear of those $350 junk parts. People that say they do something are going by placebo effect. The "box" says it adds 12 hp...so they believe it. The ONLY truth in cold air intakes and things like vortex toys is that the guy selling them has YOUR money for these costly parts that do nothing for a semi stock engine. If your car goes faster its because your wallet is lighter... !
VERY
no
FWIW
yes
VERY
no
FWIW
VERY
no
FWIW
ugh, don;t want big repair bill on something that doesn't make it look better or go faster, smoother!
MZee
When you get the bearing checked, go to someone who knows these cars. If it does need a rear bearing, they can be pricey, so check some of the forum vendors first.
If the radio was on or even the fan, I wouldn;t notice it.
Mzee
After driving it, the sound is gone, weird.If it returns I guess a wheel bearing is the issue,
Mzee
Cruise-In II Veteran
My prior '88 developed a "clicking" in the RR on acceleration. When I pulled the wheel/tire and rotated the rotor I could see slight rotation of the half-shaft w/o any rotation of the diff shaft==U-joint.
I ran a K&N in the prior Vette and in this one too. This time I just picked up a used AF lid and cut out all the louvers for added air flow. This mod IS worth ~10chp gain.
You can pick up another "free" 10chp gain by tossing that "frisbee" disc from front of your WP pulley. This too was verified in trap speed increase.
Don't waste the money on a K&N or any other snake-oil. If you plan on keeping the car, use only a high quality paper filter. The others just let more dirt into your engine. L98's do NOT have a restrictive air intake path. Read this:
http://www.getdieselpower.com/my04do...r_Testing.html
Mick
MZ,
Mick
Mick
Thanks,I think I read it right.No K and N
MZee
That is just one of many tests involving the K&N type filters and the huge amount of dirt they pass until they are very dirty.
The half shaft uni joints are the most likely place the noise is coming from. Raise the rear of the car and get underneath, slowly rotate the half shaft and listen for any click or squeaking noises.
Usually the outer one goes first (the one closest to the brakes), on average I tend to replace my half shaft uni joints every 4 years, all the power goes thru them and they take a beating. Naturally replace all four as the others wont be much better.
The wheel bearings should do a good 150,000 to 200,000 miles, i have my originals in my 85 vette that has done 175,000 miles.
(I hear the aftermarket wheel bearings are pretty bad from the stories i have seen on this forum), so get a well known brand if it turns out to be a wheel bearing.
If I get the rotor machined or replaced, that solves it.
Thanks very much!
MZee
Slingshot
If it turns out that you need a rear wheel bearing, I have one that you can have for $50 + shipping. Can send you pics if you need it and are interested.
P.
P.
Hi, I still do not get when I cut the louvers on the air intake tomorrow morning, this long weekend! I wont get water leaking right into throttle body and engine when it rains?
MZee
MZee
Paper filters absorb the water and should be changed after they get wet.
The cotton or foam filters perform better in wet conditions. Your air filter does not get direct rain water so unless you are in a huge downour and your hood is open, don't worry about it.
I'm getting a mesh cover for my filter soon but I don't drive it much in the rain. http://tinyurl.com/k99cyev
Mick
Mick
[QUOTE=QZRBLU;1583949935]Paper filters absorb the water and should be changed after they get wet.
I'm getting a mesh cover for my filter soon but I don't drive it much in the rain. [url]http://tinyurl.com/k99cyev[/url
Hi there. Thanks. I looked up the eBay filter for 55.00. Where does that go? Take the louvers off? Put a paper filter in front?
[QUOTE=MZee;1583959221]
Go back and read it again that is a cover for your filter, it replaces your stock louvered cover.
