How do I purge the air out of my 94's cooling system?
Old 08-06-2013, 03:59 PM
boonie c4
Support Corvetteforum!
boonie c4's Avatar
Default How do I purge the air out of my 94's cooling system?
Ok I've just replaced my radiator in my 94 but now I need to purge the air out of the cooling system, how do I?
thanks boonie
Old 08-06-2013, 07:59 PM
AirForceOne!
AirForceOne!'s Avatar
Here's a good link to a thread.
http://forums.corvetteforum.com/c4-g...g-problem.html
Old 08-06-2013, 08:17 PM
don hall
don hall's Avatar
The LT1 is self-purging........ fill the surge tank, idle the engine with the cap off.........when the tstat opens, add coolant, if necessary, replace cap. Done.
Old 08-07-2013, 12:17 AM
higgyburners
higgyburners's Avatar
I believe in the Beer Fairy
St. Jude Donor '15,'19
bleeder screws are located on the thermostat housing and on the throttle body.
don't forget to put a towel down so the Opti doesn't get wet
To How do I purge the air out of my 94's cooling system?
Quick Reply: How do I purge the air out of my 94's cooling system?
