replacing #74 bulbs in 84-89 instrument cluster
Old 04-15-2013, 09:46 PM
HAD2HAV2
HAD2HAV2's Avatar
Default replacing #74 bulbs in 84-89 instrument cluster
Can I change the turn signal & hi-beam 74 bulbs without pulling my 88 main cluster? I see how to get the halogens out. The 74's look hidden behind a lens.
Old 04-16-2013, 12:10 AM
Cliff Harris
Cliff Harris's Avatar
Since my bezel just happens to be off right now...
The lens is held by two plastic buttons that you can pop off by prying with your fingernail. That exposes the bulbs. Since they are a wedge base bulb they ought to come out the front, but I didn't try to get them out.
Old 04-16-2013, 01:06 AM
JrRifleCoach
JrRifleCoach's Avatar
Location: Freedom is never more than one generation away from extinction.
St. Jude '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-‘19-'20-'21-'22-'23-'24
Now I'm not sure of the numbers so I'll attempt to best describe my change.
The socket that supports those HOT dash panel bulbs is interchangeable with the sockets from the DIC panel.
I swapped in these lower wattage sockets and bulbs to reduce the heat in the dash.
Yes the dash is not as bright as it once was. But still legible in the sun, cooler and just as reliable.
Oh yeah, and a lot less expensive.
Old 04-16-2013, 08:39 AM
HAD2HAV2
HAD2HAV2's Avatar
Thanks. I saw the buttons but did not attempt to remove. I know what to do now. I have Xenons to replace the halogens but the 74's are not on all the time so little heat is built up.
Great responses. The Service Manual does not tell you these things, just take the cluster to a certified shop.
To replacing #74 bulbs in 84-89 instrument cluster
Quick Reply: replacing #74 bulbs in 84-89 instrument cluster
