Rear Differentail Fluid Change Questions
I actually did this a few years ago to my 96 and now want to to do it for my 95 ZR1. Funny thing is I forgot how I did it. What side is the plug on? What size is hex wrench does it take? What is best way to access plug? If I recall I had the car up on ramps and jacked the rear of the car up and placed on stands. If I recall if was a real pain to get to.
I have a vacuum pump and all the tools at least.
FSM specifies I believe 80W-90 GL5 and GM additive. Lubricants have improved through the years and you can consider the FSM as I guess a "minimum" spec. The debate can be likely a couple pages. I've always used the GM fluids. Habit!
The original I still have is 1052271 and 1052358 for additive. Both I believe have recently changed part numbers.
KJL - you asked fill plug size - 3/8 hex I believe if original. You asked how? It will all come back to you!
That debate happens pretty frequently and is a "personal choice"!
KJL - you asked fill plug size - 3/8 hex I believe.
Takes all the 'guesswork' out of the equation .
KW
The size for mine was one big vicegrip.
*people mention using 2 if they have problems - I don't know that actually helps.
Thanks for the feed back, I believe I have an allen 3/8" socket already, I guess I will need to remove the passenger side rear wheel and jack the car up access.
I use Amsoil 75W90 no additive
Work great but right after the change i had to make 8's figure in a empty parking lot to get the fluid to the clutch in the diff...
MTCW
