wheels stick out on drivers side - need help
Someone else on the forum posted the same problem about 6 months ago, and I don't know if they got it solved.
The wheels on my 86 (with 88 wheels) stich out about 1/2 inch on the drivers side (both front and rear) and it is driving me nuts.
I have checked the wheel backspacing, wheel bearings, knuckles and everything and nothing is different from one side to the other. The tires show no abnormal wear.
Could this be a wheel alignment issue? What does the camber adjustment bolt in the rear do? Does it adjust the wheel in and out?
This is really driving me crazy, any help would be great.
JMR
JMR
Re: wheels stick out on drivers side - need help (CrazyBlk86)
Do the passengers side wheels look normal?
Sounds like your wheel angles are totally screwed up (or in the worst case your car has been is some serious accident and was repaired poorly).
I recommend you get your car professionally 4 wheel adjusted by a shop with good moders equiptment. It is really difficult to do this properly by yourself, there is 2-3 angles per wheel. If this is done badly or not at all you WILL ruin your tires very fast. Secondly if they are wrong the car might be worse to drive than when they are ok.
Surprisingly, camber adjustment bolt adjusts camber. ;) Basicly how much the tires top edge leans in or out. Compare the 2 camber bolts, they have little position markers, are they adjusted the same way on the both sides? If there is a big difference you can be sure the angles are in need for adjustment.
My left rear tire was sticking out like you describe when I bought the car. It was fixed with 4 wheel adjustment. this has great effect on normal handling and driving.
Good luck.
Toni
Good luck.
Toni
Location: Airport Cruise-in 1 Veteran Airport Cruise-in 2 Veteran
1 Post
Cruise-In II Veteran
Re: wheels stick out on drivers side - need help (ToniH)
If anyone is looking for a fair condition stock 87 9.5, keep in mind War Machine has one sitting in storage. ;)
