Recommended header bolts
Old 03-09-2013, 04:07 PM
boceltics17
boceltics17's Avatar
Default Recommended header bolts
I have tried the stage 8 bolts. They still backed out, bent the retaining washers. With the large tubes, you have to rely on the allen head to torque them. You can barely get them up to torque. Are there any other suggestions?
Old 03-09-2013, 04:56 PM
LoneStarV
LoneStarV's Avatar
Aint cheap but....
ARP Stainless Steel Header Stud Kit
Breslin split locks
Old 03-09-2013, 07:49 PM
armysnipe
Support Corvetteforum!
armysnipe's Avatar
If you have the clearance to use safety wire pliers I recommend ARP stainless bolts with the "NASCAR" type holes. They have never backed out or loosened on me. I'm using them on an LT-1 with Doug's shorty headers. I went with the 12 point because clearances were tight. I also installed them with the engine out.
Old 03-10-2013, 12:33 AM
Midnight 85
Midnight 85's Avatar
Finalist 2020 C4 of the Year - Modified
I use ARP's NASCAR style also, 5/16 12 point head makes it easy to work on even in the tightest areas.
Old 03-10-2013, 01:28 AM
383vett
383vett's Avatar
Received 1,541 Likes on 1,042 Posts
Ditto.
To Recommended header bolts
Quick Reply: Recommended header bolts
