C4 Automatic Transmission Shifter Problem
5th Gear
I have a 1996 LT1 automatic and I am having an issue with the shifter. When the shifter is in the overdrive position, it can inadvertently slide forward into the neutral position and the transmission faithfully shifts into neutral. The transmission otherwise performs flawlessly if pressure is held on the shifter back towards the overdrive position, and both park and reverse shifter positions work correctly as well. I would expect some type of resistance when moving the shifter from overdrive to neutral, but there appears to be none.
Question: Is there something worn here, or possibly some type of adjustment for this?
There is an adjustment on the transmission end of the shifter cable. Put the shifter in Park and remove the cotter pin and shift cable from this lever. Then loosen the 15mm nut on the back of the shift lever and move the pin until the shift cable slips onto the pin. REMOVE THE SHIFT CABLE FROM THE PIN. Tighten the nut securely. You will break your shift cable if the lever moves while tightening the 15mm nut. You don't need to ask how I know this...
my 96 has a problem with going into park. sometimes when i park on an incline it starts rolling and clicking like a parking pin or something. i have to jiggle the shifter to get it to lock in. think this is the same issue?
Sounds like an adjustment is in order. There is no adjustment on the shifter. It has to be done at the transmission.
The parking "pawl" is on a lever that pivots and locks into notches in the reaction ring gear support. If it doesn't engage completely then it can make a clicking noise as it bounces over the notches (on the left):
It's best to have 2 people to adjust the linkage, much better then having to jump up and down...I had the complete opposite problem you have..Mine wouldn't allow me to pull all the way into first gear so I could shift manually..A little bit of adjustment on the cable at the trans and it works great now....WW
I had shifter problems on the 86 I had. It had trouble going into Park.
That was an easy fix. The bolts holding the cable bracket to the tranny were just loose. Hope yours is that simple.
5th Gear
Thanks Cliff. In addition to my shifter sliding into neutral from overdrive, I also cannot pull it all the way back into 1st, so I think you are definitely onto something. I cannot quite make out your procedure, but I'm guessing that when I crawl under it I will better understand. I should be able to do that tomorrow and I will let you know how it goes!
