So some moron welded up my rear toe rod....
Old 01-30-2013, 08:43 AM
bassackwards
bassackwards's Avatar
Default So some moron welded up my rear toe rod....
And I need a new one. They welded the inner and outer together and now I can't replace the worn outer.
I can't seem to find a replacement.
Any ideas?
Old 01-30-2013, 09:13 AM
Txbobcat
Txbobcat's Avatar
I sent you a pm where to get it
Old 01-30-2013, 09:14 AM
Sleazy Rider
Sleazy Rider's Avatar
i have one out of my 89 that i replaced in 90 with a unit from tommy morrison, less than 10k on it.
Old 01-30-2013, 09:15 AM
WVZR-1
WVZR-1's Avatar
Received 2,266 Likes on 2,027 Posts
Is it a secret?
The catalog suppliers all have them -
Old 01-30-2013, 09:20 AM
bassackwards
Originally Posted by WVZR-1
Is it a secret?
I can't find any. I found a whole assy for $400 but I don't need it all.
Old 01-30-2013, 09:38 AM
WVZR-1
WVZR-1's Avatar
You said the outers were welded to the inners? If that's the case you need it all! Explain if I'm misunderstanding here!
Old 01-30-2013, 09:52 AM
bassackwards
The rt side is OK, the left side is where the trouble is.
I may be able to get the outer tie rod off but someone welded the jamb nut to the inner rod real good. There is also a piece of pipe welded in there. I mean good. No bubble gum weld, they got full melt fusion in there.
Old 01-30-2013, 09:55 AM
bassackwards
Old 01-30-2013, 09:56 AM
WVZR-1
WVZR-1's Avatar
I believe CC has everything for $275 maybe. Now there's a change in '92 in the outer tie rods so you need to make sure whatever you do that you've got matching parts. You could use an '88 - '91 assembly but you can't combine pieces.
I'm guessing that there was an impact left rear and that's how they "cobbled" the fix.
Old 01-30-2013, 10:06 AM
bassackwards
When I did the fronts, I had to use 93 inner tie rods. The one they said fit 92 did not fit.
Old 01-30-2013, 10:15 AM
WVZR-1
WVZR-1's Avatar
'92 inners were a one year only and if the car had ever had a service rack installed it would likely have been an updated assembly. '93 to end of production inners are different!
Do you agree on the impact likely and the fix?
Old 01-30-2013, 10:19 AM
bassackwards
I'm not sure what happened in there. It is very straight and tight and appears to have never been painted.. I guess it could have taken an impact to the wheel area but nothing seems damaged except for this part.
I'd just like to replace the sleeve assy if possilbe, the inner joints feel tight
Old 01-30-2013, 10:27 AM
WVZR-1
WVZR-1's Avatar
For less than $300 and some time you can have a "good/reliable" fix that should insure good rear axle toe control which effects drive-ability, car control not to mention tire wear. I'd say it looks like a good investment.
Old 01-30-2013, 12:56 PM
MK 82
MK 82's Avatar
Salvage yard.
Old 01-30-2013, 02:47 PM
383vett
383vett's Avatar
Received 1,541 Likes on 1,042 Posts
Stop calling me a moron.
Old 01-30-2013, 02:57 PM
Crepitus
Crepitus's Avatar
Old 01-30-2013, 03:26 PM
TA
TA's Avatar
Looks like good ole fashioned ingenuity to me
To So some moron welded up my rear toe rod....
Old 01-31-2013, 12:14 AM
84wannabezo6
84wannabezo6's Avatar
You can get the heim joint style from vette brakes for around 300 for everything
Old 01-31-2013, 07:29 AM
leesvet
leesvet's Avatar
You need it all.....
Old 01-31-2013, 02:06 PM
Elrick
Elrick's Avatar
There is one for sale in the parts section off a 90 for $50. can't beat that
Quick Reply: So some moron welded up my rear toe rod....
