Best Slave Cylinder to buy for 84-88
Hey folks,
Took the 84 vette for a drive the otherday. clutch felt a little funny, engaging way to close to the floor, having to pump it to get any clutch pressure. Now its got zero pressure. the pedal was squeaking for along time before, thought maybe it was just a rusty pedal or something but this makes sense.
Master cylinder is new
im like 99% sure its the slave cylinder.
Whats the best slave cylinder to buy? i've seen them anywhere from $50-$170 all from reputable dealers like zip and mamotorworks. im curious what everyone else is using.
my original clutch was a leg buster VERY tough to push in. im looking for something that has the touch like a newer car if thats possible.
cheers! and I appreciate the help
ordered a Rhinopac/world car slave cylinder from rock auto for like 40 after shipping. Ive heard it mentioned on other forums. I was looking specifically for something 100% cast rather then the two piece molded one like the original delco.
ill keep you guys posted on how it turns out for those in my same predicament.
It's worked great...so why not.
I wouldn't toss the old one and if I had a cast one I'd probably inspect the piston because it's likely assembled with a piston and seal that actually is very available in the open market. Hone and reseal!
im kind of a broken part hoarder lol, so I will be. problem is when you re hone them you need a bigger seal. which may cause it to be weaker. the smaller the seal the more responsive the clutch is as well, at least to my understanding.
You'll find that on your '84 the bottom fitting is odd and the cookie cutter Slaves from Parts stores won't be compatible. You'll need to buy the A/C Delco slave or change the hose end...
I am not sure of the later years as I've not heard many others ever mention this issue...but when I was doing a the Slave, I had to find that brand or change the hose.
And don't discount the fact that the Master is bad......I am on my third Master from Kragen/O'reilly......I replaced it three years ago and it already went out.....put another in there and it lasted a month, warranty the part and replaced it again.....
I am thinking to go back the AC/Delco place an buying another OEM.....
Rockauto has a huge selection of hydraulics. Have heard good things about Sachs brand....., but I would cough up the extra coin for Delco brand hydraulics.
thats just it, ive heard the delcos are the 2 piece welded design rather then the cast. some people have reported leaking from the seam. I figured id give the bulkier cast one a shot. ill open it up check the seals for quality then throw it on there.
