85 no start
Old 01-24-2013, 10:27 PM
msapp3ster
msapp3ster's Avatar
Default 85 no start
My 85 will crank has fire won't start,replaced fuel pump,starter
Old 01-24-2013, 11:29 PM
ghlkal
ghlkal's Avatar
Finalist 2020 C4 of the Year - Modified
2018 C4 of Year Finalist
You've verified you have spark?
Do you have a fuel pressure gauge to check the pressure in the runners?
Old 01-25-2013, 12:11 AM
Cliff Harris
Cliff Harris's Avatar
You need to check fuel pressure and make sure the injectors are firing.
Fuel pressure gauge and "noid" light. Or you can see the injectors firing with a digital voltmeter. The voltage will jump around with the injector pulses.
One wire is 12 volts, the other is the injector signal from the ECM. With the engine not running you should see 12 volts on both pins of the injector connectors. Check both banks, as there are two injector fuses, one for each bank. All 8 injectors fire at the same time so you only need to check one injector connector on each bank (to make sure the wiring is OK).
Old 01-25-2013, 01:51 PM
msapp3ster
msapp3ster's Avatar
I have spark and pressure at the fuel rail?
Old 01-25-2013, 02:24 PM
John A. Marker
John A. Marker's Avatar
Is the spark strong? Does the battery have a full 12 volts?
Need to check pressure at the fuel rail on the passenger side of the fuel rail.
Have you recently done any work on the car????? IF so, then what was done?
Old 01-25-2013, 04:33 PM
leesvet
leesvet's Avatar
if you have spark and pressure (40 psi) in the rails...then that leaves the injectors. They must cycle for the engine to even burp.
you say the engine does turn over? rotates but will not fire and run?
if this is pre-VATS, then it has to be the inj circuit. Verify inj operation with a noid lite. If there is no inj cycling then trace that back to fuses, the power source at the battery jumper pole, and ECM grounds on the block.
as someo0ne stated, if there was recent work and it was ok prior, go thru that work and look for something damaged.
curious.....
why was the starter replaced if the engine would turn over? what told you to change fuel pump? was there no fuel pressure? what test did you do or was this diagnosis by checkbook?
Old 01-25-2013, 04:35 PM
msapp3ster
msapp3ster's Avatar
spark is strong pressure on passenger side fuel rail 48 ECM checks out . No I haven't done any work on it .
Old 01-25-2013, 04:42 PM
msapp3ster
msapp3ster's Avatar
starter went out after this problem started fuel pump just replacing old part also fuel filter replaced
To 85 no start
Quick Reply: 85 no start
