Corvette Forum
Go Back   Corvette Forum > C4 Corvettes, 1984 - 1996 > C4 Tech/Performance
Register Forgot Password?
Register Vendors Buy a Vette Albums Search Today's Posts Mark Forums Read FAQ TSB & RecallsGarage
Search
C4 Tech/Performance
L98 Corvette and LT1 Corvette Technical Info, Internal Engine, External Engine Sponsored by
J&D Corvette
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 01-23-2013, 03:43 PM   #1
prestige6
CF Senior Member
prestige6's Avatar
Default won't crank vats
Reason I'm here I hope all GM vats systems are pretty much the same. I just bought a 95 caddy deville,was running fine,now won't crank. Read up on the vats system and measured the resistance in the key came up with 9.49K went to radio shack got 2 4.7 resistors cut the orange lead that comes from the ign. switch put the resistor between the two white wires in the Orange sleeve. Still No Crank.. Any advise what to do next.. Thanks
prestige6 is offline   Reply With Quote
Old 01-23-2013, 03:59 PM   #2
WVZR-1
CF Senior Member
Quote:
You have them in a series "end-to-end"? Depending upon the tolerance percentage of the resistors you could still fall beneath the "minimum threshold" for the resistance values! Did you check the resistors before installing? Do it now! If they were 10% resistors you could be well below the threshold, 10% high and it's well out high. Actually 5% resistors could also.
I see posts on the Cadillac Forum and here! Are those the only two? Likely not!
WVZR-1 is online now   Reply With Quote
Old 01-23-2013, 04:02 PM   #3
prestige6
CF Senior Member
prestige6's Avatar
Quote:
Measured them and it came within the tolerance of 2% also took the other key I have and put the wires on that to act as a resistor still nothing..
Old 01-23-2013, 04:11 PM   #4
vetteoz
CF Senior Member
vetteoz's Avatar
As with any other GM VATS system also you have the starter enable relay operated by VATS which is a possible fault point.
VATS may be reading the key / resistors correctly but if the relay is bad you will get a no crank situation
Simplest test would be to hot wire the starter to crank the engine over.( Key on )
If it fires up (VATS shuts off the injectors ) you know the problem is with the starter circuit ie;
Ign switch , relay , P/N switch or the wiring itself to the starter solenoid
vetteoz is offline   Reply With Quote
Old 01-23-2013, 04:11 PM   #5
leesvet
CF Senior Member
leesvet's Avatar
huh uh-huh
That key switch is not the only part of VATS...
you also have the starter enable relay, which is a common failure and the first place to test the system. What SHOULD be done is test the orange cable with the KEY inserted to ON/RUN and see if there is the same resistance as going across the key pellet. THAT is how you tell if the key switch is working or not. If the resistance is OK< move on the relay then finally to the VATS module. The FSM for any GM car will describe the complete step by step diagnostic for VATS.
leesvet is offline   Reply With Quote
Old 01-23-2013, 06:47 PM   #6
WVZR-1
CF Senior Member
The system needs diagnosed in order but if you wanted to jump to parts replacing etc the neutral safety switch is/was a frequent nuisance. You could check the voltages in and out and move forward. With your VATS by-passed can you take 12V to starter and crank? The N/S switch can be very intermittent. Which engine? That adds to the possibilities!
Old 01-24-2013, 12:03 PM   #7
prestige6
CF Senior Member
prestige6's Avatar
I tested the Orange lead with the 2 white wires in it from the Ign. key switch.9.49k so this means No Broken Wires.. I was able to pull these codes from the DTC can anyone tell me if they would have anything to do with the No crank,before i go any further....I 052 P 052 I 033 I 039 Thanks..
Old 01-24-2013, 12:24 PM   #8
WVZR-1
CF Senior Member
None appear related! I asked which engine? You've not answered. Did you check N/S switch? No.
http://z-cut.de/US/dtcobd1.html
Old 01-24-2013, 12:39 PM   #9
prestige6
CF Senior Member
prestige6's Avatar
4.9 motor Didn't check the NSS switch yet,Where's it located.. I'm doing this outside and it's so Friggen Cold...
Old 01-24-2013, 01:10 PM   #10
WVZR-1
CF Senior Member
Under-hood at shift selector I believe. You should do much better over where you started on the Cadillac Forum. I'm familiar with the procedure to check but I can't lead you through it.
Old 01-24-2013, 02:11 PM   #11
prestige6
CF Senior Member
prestige6's Avatar
I think you are write on the money with the NSS I just jumped the starter and Wala it started. Now when I warm up again I'll test and replace NSS switch .. Thanks
Old 01-24-2013, 02:41 PM   #12
WVZR-1
CF Senior Member
The NSS isn't inexpensive - do your diagnostics first! Don't just jump in like you did the VATS! Post back!
Old 01-24-2013, 04:10 PM   #13
prestige6
CF Senior Member
prestige6's Avatar
I know it's around 100.00
Old 01-25-2013, 06:47 PM   #14
prestige6
CF Senior Member
prestige6's Avatar
Where is the starter relay. Looked all over can't find it.Does the car have one???
Old 01-25-2013, 07:28 PM   #15
WVZR-1
CF Senior Member
You'll love this one. I believe it's taped to the body harness in the vicinity of the drivers "kick-panel" maybe more towards the the rocker. This link should work for you:
http://ww2.justanswer.com/uploads/JF...95_deville.pdf
Remove the sill plate and pull carpet back. I don't believe it that tough once you know you're looking in the proper area. The rest of your relays and maybe the theft deterent is maybe in the trunk attatched to the left side of the rear seat.
Enjoy!!!
Old 01-25-2013, 07:28 PM   #16
prestige6
CF Senior Member
prestige6's Avatar
I just found that link also. I checked the NSS and it tests good,so I'm leaning towards the fuse in the trunk or the relay..See what tomorrow brings... Thanks
Old 01-26-2013, 11:14 AM   #17
prestige6
CF Senior Member
prestige6's Avatar
Enjoy!!!
I'll be damned,but I can't find that relay.......
Reload this Page won't crank vats
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.2
Emails & Password Backup
