Corvette Forum
Go Back   Corvette Forum > C4 Corvettes, 1984 - 1996 > C4 Tech/Performance
Register Forgot Password?
Register Vendors Buy a Vette Albums Search Today's Posts Mark Forums Read FAQ TSB & RecallsGarage
Search
C4 Tech/Performance
L98 Corvette and LT1 Corvette Technical Info, Internal Engine, External Engine Sponsored by
J&D Corvette
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 01-18-2013, 09:40 PM   #1
nummy
Junior Member
Default Another newbie question.....
Hello again everyone -
I have another rookie question.
When a C4 (1996) left the factory, what color was the outside of the floor pan?.....I'm referring to the area facing the ground that hangs slightly below either side of the center supports. (the brake lines run along-side of it, front to rear)
Just wondering if it's supposed to be black, primer, or color-keyed to match the exterior paint color of the car.
As always, thanks for your time !
nummy
nummy is offline   Reply With Quote
Old 01-18-2013, 11:17 PM   #2
leesvet
CF Senior Member
leesvet's Avatar
huh uh-huh
depends..some had a coating...some not. Some dealerships applied their own sound deadening/insulating material. Never seen one color matched to the body.
leesvet is online now   Reply With Quote
Old 01-18-2013, 11:29 PM   #3
ghlkal
CF Senior Member
ghlkal's Avatar
Wow, that's a good question. I don't know
IIRC there's some body color overspray on the sides of the pan of mine - at least I think it was just overspray and not GM trying to paint them.
I'd be interested in the answer to this too
ghlkal is offline   Reply With Quote
Old 01-18-2013, 11:56 PM   #4
nummy
Junior Member
It seems like the entire outer surface of the floor pan (SMC or fiberglass?) is already tinted red, and not overspray....if that's even possible.
Not sure how the C4 was assembled in its day, but I assumed all the body panels were prepped and painted prior to being attached to the car itself, so I'm not sure where over-spary would even come in contact with the floor pan......but then what do I know, I'm a rookie !
nummy
Old 01-19-2013, 12:08 PM   #5
mtwoolford
CF Senior Member
kinda ugly non descript grey
mtwoolford is offline   Reply With Quote
Old 01-19-2013, 03:40 PM   #6
ghlkal
CF Senior Member
ghlkal's Avatar
I can't tell if the floor pan has some kind of coating (noise reduction?) or not. Maybe that's just years of grime.
On my gray 1985, the floor pan is gray under the "coating"
Click the image to open in full size.
On my red 1990 Z, the floor pan is red under the "coating"
Hmmm ...
Old 01-26-2013, 12:14 AM   #7
nummy
Junior Member
A body shop pal of mine confirmed that my C4 was painted from the center molding downward, which explains the over-spray.
I'm going to remove the rocker panels and cover the over-spray with a little Krylon flat black. Now if I can figure-out how difficult it is to remove the rocker panels.....Hmm
Hmmm ...
Old 01-26-2013, 12:40 AM   #8
Cliff Harris
CF Senior Member
Cliff Harris's Avatar
My floor pan has some kind of thick black tar like gunk sprayed on the bottom. I assume it's supposed to be sound deadener.
Cliff Harris is offline   Reply With Quote
Old 01-26-2013, 12:44 AM   #9
WVZR-1
CF Senior Member
You asked how to and how difficult yesterday or the day before. You've not forgotten already OR have you?
WVZR-1 is offline   Reply With Quote
Reload this Page Another newbie question.....
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.2
Emails & Password Backup
