**New Performance Optispark for your LT1/LT4!**
#41
Supporting Vendor
OEM Replacement Distributor is designed for enthusiasts that are serious about performance.
#45
Wouldn't it be great to find a reliable source for the opti... Petris is pricey but if they have longevity, it's still a value. Just imagine the time you'd save NOT replacing a cheep failed one. 1 x and you lose that extra $250 u think u saved.
Do you guys convert the non vented units to a vented unit? I have a 93 w/ non vent. Seems the vent to pull off possible moisture is a winner (95/6 c4).
#47
Car only has 34K on the odometer and thought I'd be proactive b4 problems set in .
Depending on how old your water pump is , make up a drain line for it as well , in case the water pump spits , it won't short out the optispark
#48
