Rear main seal leaking.
I'm down to the last leak on this vehicle, the rear main seal.
There is a how-to on the internet about replacing a SBC 2-piece main seal without much more than removing the oil pan, oil pump and rear main cap.
Does anyone have any insight/suggestions/how-to's on performing this? Part numbers? Special tools? Tips and tricks?
Thanks,
-Scott
Thanks,
-Scott
Thanks,
-Scott
Thanks,
-Scott
Thanks,
-Scott
Thanks,
-Scott
For starters, if you have an '89 you have a 1-piece rear main seal. Totally different than a 2-piece. Out comes the transmission and off comes the oil pan. All of the "how to" is in the Factory Service Manual and in numerous threads. No special tools are required, just normal mechanic tools.
See above post..Follow FSM
