Starting Question 93 LT1
I have what may seem like an odd question. I have a 93 LT1 Vette that when it starts after being hot, its hesitates a little but it does start. Also it makes a loud whine from the engine bay right after it starts. At first i thought fuel pump but i know that's normally from the rear. Most of my vettes are older than this one. I actually just got this one. has 90k miles and wanted some imput. FYI never had any of those issues when i test drove it (doesnt that figure)
Thanks,
Thanks,
The belt was replaced a month ago. Just odd. I am pretty mechanically inclined. Worked on all my cars for years. Its odd because event though this is fuel injected, if you give it a little gas when starting then it fires fine. But if not when its hot, its take some time. Kinda like starting my 78 cold but i know its not supposed to be that way.
I would start be checking to vacuum line for the FPR (fuel pressure regulator) to see if it is wet and has fuel in it. Pull up the plastic left engine cover and look to rear of engine. That would cause hard starting after shut down.
I can't comment on the loud whine. However, after starting the air pump usually starts and you may be hearing that??
